Seeing the same issue. The only printer options are Ultimaker printers
Hi mnswamp did you resolve not being able to add a custom printer I’ve downloaded version 4.6.0. And 4.6.1 and again only Ultimaker printers in the add printer list no option to add custom printer or the fff one as per the user guide ?
The display properties of Cura must be intended for people with really, really big monitors. The scroll bars for that form are hidden/nearly invisible. If you get right on the right edge of the window with the Ultimaker printers in it, you can eventually get the scroll bars to appear. I'll try to get a screen grab off my other machine and post up.
Once you get the scroll bars to move, all the printers show up like you would expect.
Thanks that works perfectly cheers Rob
1 hour ago, VOCAPTAIN said:Thanks that works perfectly cheers Rob
Please, give me screenshot...
Hi thanks yes that works perfectly, i was just adding screen shots to show you can still edit the custom FFF printer for both printer and extruder
ahoeben 1,850
Can you try "Activating" one of the other printers using the Activate button? Do the other printers have "Machine Setting" button once they are activated?
Edited by ahoebenLink to post
Myrkytyn 1
Yes, i can ativate printer. But i have also nothing in settings.
For example if i add and activate Ultimaker Original - i have these menus (Cura 4.5)
