Cura won't show the imported profiles in the dropdown menu
tognaco
Posted · Cura won't show the imported profiles in the dropdown menu
I was using Cura 4.2 and tried to import two profiles for my Ender 3: a .gcode file and a .curaproilfe one. Well, according to Cura the importation was successful, but when I go to the profiles dropdown menu, only the default profiles and the ones that I myself created are shown. The recently imported ones are nowhere to be seen. I uninstalled Cura and upgraded to 4.5, but the same thing happens: it keeps not showing the imported profiles. Any advice, please?
    • 4 months later...
    • 4 weeks later...
    • 2 weeks later...
    Just happened to me as well on Cura 4.7.1. I am trying to import some previously saved config profiles and they are not showing up after successfully saying it has been imported. After doing this a few times I start to get a "(#X)" next to the name of the import in the success window. This does nothing for visibly seeing the profile.
