I cannot completely follow you with the two layers.
I do not know if I am wright, tried to write it as question, because it's tricky.
Let's say you print 2 towers. layers 0.1mm
With single extruder; left layer 1, right layer 1, Right layer 2, left layer 2, left layer3 etc. etc etc.
Normally, but for sure in this case, the (Theoretical) clearance is always the paper and layer thickness I started with.
But now I make 2 towers extra, 4 in a row..
The movements at least in 13.11 are the same as for 1 extruder.
So color 1 from left to right. Z down. layer 2 from right to left.
Next comes colour 2, that has to drop 2 layers down? As far as I can see it.
And for sure hits a little bit the other colour?
As I said before, I give it another try tomorrow to be sure, might be wrong.
But for now I think the clearance is 2 layerthickness(es) or none.
It would be more precise if it printed one layer at a time, so finish one layer before stating another one.
Dim3nsioneer 556
I guess everybody was waiting for Daid to include the dual extruder stuff... :wink: I plan to try it next week...
These are some very good questions / remarks, I think.
I cannot completely follow you with the two layers. As far as I see it, Cura (I refer to version 13.10 here as I did no dual extrusion so far with 13.11 or 13.11.2) starts with an extruder at one layer (let's call it no. 1) and goes with this extruder onto the next layer (no. 2). It then switches to the other extruder on layer 2 and continues until layer 3 where it switches back to the first extruder and finishes the layer 3 and goes onto layer 4 and so on... Thus, it should only see 0.12mm difference, never 0.24mm... right?
Assuming the two hotends to be positioned on the same height (which is indeed VERY tricky with the current setup, but not completely impossible), the unused hotend should have the same height as the used one and might slightly touch the printed material of the active hotend (by some microns), but it shouldn't move the material away, should it?
You're absolutely right with the leveling. It is ABSOLUTELY CRUCIAL for dual extrusion up to a level of not only 0.1mm but far more accurate. I bought myself some very thin feelers (down to 0.03mm). They give you much more information than the sheet of paper (which is absolutely ok for single extrusion, I think).
I still have the acrylic standard bed... which is a BANANA...! It's nearly impossible to get a reasonable dual extrusion leveling with this bed. People with a glass bed are far better off; they really have a chance. However, the bed is not the only influence onto the leveling quality.
What about the 6mm rails the print head runs along? Are they straight? Up to what deviation?
What about the 8mm rods the rails of the print head are mounted to?
A linear deviation is no problem as it cancels out at the end, but quadratic, cubic and so on influences do not... :sad:
This is just theoretical. As mentioned at the beginning, I plan some test next week or the week after.
