I am unfamiliar with different operating systems. I have only used Windows. I have a Lenovo Chromebook. I think the operating system is Google. Is there a way to run Cura on the Chromebook.
Thanks.
Thanks.
44 minutes ago, omniderb said:Is there a way to run Cura on the Chromebook.
If your chromebook supports running Linux which a lot of them do these days then you can run the Linux AppImage. Here's a thread that talks about running Cura on a chromebook
Thank you for your help. It looks like there should be something called Cura.appimage available. When I do a search for it in Ultimaker, the only info I get is answers from the community. I can’t figure out how do download the Cura.appimage.
Ok, after stumbling around and banging into walls, I finally found the cura.appimage at github. I’m downloading it now. The next question is I am supposed to make it executable using my file manager or by entering certain commands into a terminal. What is a terminal? Where is the file manager.?
Thanks.
I guess it doesn’t matter anymore. The download gets just so far and quits. I’ve tried it few times but it refuses to complete.
burtoogle 495
If not Windows, what does it have? If Linux, just use a Linux release.
