Holes in Cura model
nsanti
Posted (edited) · Holes in Cura model
I have just reset Cura because of this problem, but it still exists. In this benchy model there are gaps all along the model. No matter what model I put in, the holes exist. I am using a Monoprice select mini v2 and Cura is set to Malyan m200 which is the same machine. I don’t have this issue in ideamaker, but I want to use Cura because of the machine preset
Edited by nsanti
    Posted · Holes in Cura model
    Coasting stops extruding a bit before travel moves so pressure in the hotend (or bowden tube) releases gradually and there is less stringing.
