Temp changed nothing on this particular issue.
Motor is fine, has no issues in all other cases, simply this edge case issue.
Bed level is good.
Slicer settings is more likely part of it, but that's the rub, i'm not sure exactly what the slicer is doing that might result in the issue.
I'v varied anything i know to have an effect including:
retraction speed/distance
temp
Acceleration
extra prime amount
linear advance
etc.
But none of them seemed to touch the issue noted in the test situation without being taken to extremes.
Under-extrusion at start of some lines
12 hours ago, Zackorion15 said:Temp changed nothing on this particular issue.
Bed level is good.
temp
Acceleration
extra prime amount
linear advance
etc.
Interesting. Which printer is it?
Edit: Did you try to lower your speed? Your speed can be a key factor in extruding properly. If nozzle temperature doesn't help, try lowering your speed by around 5 mm/s at a time.
Try printing a few tests made specifically for under-extrusion, like literally anything. When it is printing, try lowering the speed bit by bit to see what works best. Too fast of a speed gives you under-extrusion, a missing of layers, while too slow of a speed gives your over-extrusion, so you have to find that sweet spot.
(Which is like 40-50 mm/s for some, 70-80 mm/s for others, and 180-200 mm/s for legends)
It is on my Anet A8.
Yeah, I'v tested a lot on print speed too, and for all other cases i'v found the speeds i use are just fine.
20mm/s for initial layer
30mm/s for top skin layer
45mm/s for walls
60mm/s for support/infill
All with 1000mm/s^2 acceleration
Small perimeter features printed at 50% of standard speeds.
I'm definitely not running the fastest here, nor the slowest. My testing found that the issue was less pronounced but still present with speeds cut in half. So, that tells me that the core issue is not caused by speed, just exaggerated by it.
- 6 months later...
After extensive research this post seemed to describe the problem I was having the best: 5-10mm of some but not all single width line segments were underextruded as shown after a travel move, and none of the settings that would logically fix the issue really addressed it properly. My model also has several single walled features which would be consistent with the OP's hypothesis of cura not slicing properly when switching between different width thin features. After a large amount of time playing with every setting that could remotely have anything to do with outer perimeters, I found that disabling the "Compensate outer wall overlaps" setting made the single wall extrusions behave as intended. Phew! Hopefully that helps anyone else who is seeing this issue. I don't know why this setting would change the way a single wall feature is extruded. I'm inclined to think it is a bug.
Edited by ganadyne- 1 month later...
On 11/30/2020 at 9:47 AM, ganadyne said:After extensive research this post seemed to describe the problem I was having the best: 5-10mm of some but not all single width line segments were underextruded as shown after a travel move, and none of the settings that would logically fix the issue really addressed it properly. My model also has several single walled features which would be consistent with the OP's hypothesis of cura not slicing properly when switching between different width thin features. After a large amount of time playing with every setting that could remotely have anything to do with outer perimeters, I found that disabling the "Compensate outer wall overlaps" setting made the single wall extrusions behave as intended. Phew! Hopefully that helps anyone else who is seeing this issue. I don't know why this setting would change the way a single wall feature is extruded. I'm inclined to think it is a bug.
Thank you for sharing this, in my case I disabled both inner and outer wall. Solved a problem I had been battling for days now!
Thegladster 1
Underextrusion is caused by
1. Your nozzle temperature is too low, and/or your speed is too high. This is a very common cause, check those settings.
2. Your extruder/stepper motor is worn out, and you should upgrade your motor to a stronger, more durable motor
3. Bed leveling. My bed was not leveled properly, so I leveled it and I realized that was the cause of my underextrusion.
4. Slicer settings. Make sure that your printer's profile matches up with your printer's volume, details, etc. Accuracy is better than speed if you are trying to print a sculpture for detail.
Try changing these parameters and see if it helps. 😄
