tinkergnome 922
13 hours ago, hamodeh21 said:it went over every line twice. Can I get it to draw the line only once?
I'm not sure, i think that's simply how the CuraEngine lays down the paths.
If it's possible at all, the "print thin walls" feature may influence this (dunno 🤷♂️).
tinkergnome 922
What's the value of "Retraction Minimum Travel"?
hamodeh21 0
it was set to 1.5mm, reduced it to 0.4mm and I got retractions where it shouldn't retract, set it to 0.6mm and now it works. I guess I need to tune this for different circuits. Thanks mate appreciate it :).
Also, is there a way to force it to draw each trace only once? for example, it went over every line twice. Can I get it to draw the line only once? I have my trace width at 0.4mm and the wall thickness is set to 0.4mm.
