Posted · 0.1mm Nozzle Option
Hey there!
I'm just getting started with Cura, and when I checked the Material / Nozzle settings, I didn't see an option for a 0.1mm nozzle. Is there a plugin that adds this or a way to do it natively? Otherwise, will it affect the software too much if I just set it to 0.2mm and operate as if it's actually 0.1mm?
Thanks!
    Just set the line width to 0.1mm.  Well - all the line widths.  But that's all you have to do.  Cura doesn't really have a nozzle width parameter (it does but it doesn't do anything other then set the line widths and it's hidden).  It's called "line width".
    • Thanks 1
