Posted · Cura Speed Setting issue
Hello Community,
I have an issue when I want to speed up my outer wall. It seems as soon I get above the value of 39mm/s for the wall speed (calculated: outer wall:  26mm/s inner wall: 39mm/s) the top and bottom wall speed is faster then the speed inbetween. I attached a screenshot showing this issue.
Did anybody discover similar - and is there any value I miss to adjust the outer wall speed to be uniformal from bottom to top for this higher speeds?
For reference: Cura 4.6.1; Settings for UM-S3 with PLA, 0,4mm Nozzle - Speed, Acccel, Jerk Speeds visible in Screenshot
