Temp error
spenter
Posted (edited) · Temp error
I see it has been a while since anyone has posted here but going to try anyways.
I have uploaded the latest and version 16.03 firmware and get a Temp erro.
I do not get this when original UM2 firmware is installed.
Any ideas?
Thanks
Edited by spenter
    Posted · Temp error
    Your question is a bit imprecise to say the least... 🤔
    If the actual error message is "ERROR - STOPPED  Temp sensor", you probably have installed a dual extruder variant of the firmware by accident (and the second temp sensor is not installed).
    Yes that is it exactly; only I am trying for 3 extruders. I am using a Diamond Hot end for 3 in 1 out printing.
    there is only 1 temp sensor in the print head.
    However I installed the hex file so did not make any changes in the firmware.
    Thanks for your prompt reply and help
    Daniel
    Edited by spenter
    Posted · Temp error
    Thanks for your help.
    I made the required changes in the firmware
    and am past that error "ERROR - STOPPED  Temp sensor".
    Now on to the next problem.
    Thanks
    Daniel
    Ok next problem.
    I have steeped back from 3 extruders and am trying for 2.
    I set number of extruders to 2 and verify that the two are defined in the pins.h file
    but when I upload the firmware I cannot get the 2nd extruder to move like the first.
    What am I missing?
    This is my source for this project.
    https://reprap.org/wiki/Ultimaker_Diamond
    No more ERROR - STOPPED  Temp sensor until I switch to the thermistor over the thermocouple.
    Is there any decoder to the pin mystery. I follow the pins used in the firmware but it does not
    match any thing on the micro pin numbers.
    Thanks so much in advance for your help.
    Daniel
    Edited by spenter
    Posted · Temp error
    It is not a mystery, just a mapping 🙂
    https://www.arduino.cc/en/Hacking/PinMapping2560
