Yes that is it exactly; only I am trying for 3 extruders. I am using a Diamond Hot end for 3 in 1 out printing.
Â
there is only 1 temp sensor in the print head.
Â
However I installed the hex file so did not make any changes in the firmware.
Â
Thanks for your prompt reply and help
Â
Daniel
Edited by spenter
tinkergnome 927
Your question is a bit imprecise to say the least... 🤔
Â
If the actual error message is "ERROR - STOPPEDÂ Temp sensor", you probably have installed a dual extruder variant of the firmware by accident (and the second temp sensor is not installed).
