STL doesn't have units, so everyone working with them has to make assumptions about it. Cura makes the assumption that STL are in mm. The barbarian plugin provides an easy way to switch between the two.
- 11 months later...
I have the same problem and just want to know how to install the barbarian units plugin
20 minutes ago, CRTC said:I have the same problem and just want to know how to install the barbarian units plugin
If you have an account you can add it via the web marketplace: https://marketplace.ultimaker.com/app/cura/plugins/nallath/BarbarianPlugin
If you don't have an account, you can also download it directly in Cura. You can do this by clicking the "Marketplace" button that is located in the top right of the screen.
peggyb 169
there is a plugin available in the Marketplace, the 'Barbarian Units'
