Cura 4.6.1 Helpers translucent in Line Type Layer View
willcaddy
 Share
Posted · Cura 4.6.1 Helpers translucent in Line Type Layer View
Hello everyone šŸ™‚Ā
Ā
ApologiesĀ if this is just a case of me not knowing where the option is lol but in Cura 4.6.1, the helpers (light blue colourĀ for support etc) is translucent. Now in some cases this is very useful but for the most part I preferredĀ it being a solidĀ colour. Is there an option to change this back? I couldn'tĀ find it and Google isn't helping as I don't entirely know what I should be searching for -_-Ā
Ā
I have attached an image of what IĀ mean.Ā
Ā
Thanks a lot in advance!Ā
Ā
All the best,
Ā
Will šŸ™‚Ā
Ā
Nope.
Ā
At least not easily. You could go the route of a custom theme. Switching themes requires a restart though, so it will not be a convenient toggle switch. Let me know if the amount of trouble you are willing to go through.
    Thanks for the reply mate!
    Ā
    To be honest I don't mind a semi- permanent workaround because I don't think i will miss the see-through-ness much lol What would you need to do for a custom theme?Ā
    Ā
    Thanks again šŸ™‚
    * Download this file (see the "Raw" button) as theme.json: https://gist.github.com/fieldOfView/e00ca6953754e53962196a0af4b9f256
    * In Cura go to "Help -> Show configuration folder"
    * In the "themes" folder create a new folder named "cura-nontransparent" and place the theme.json file in it
    * Restart Cura
    * Go to the General preferences and from the theme dropdown select "Ultimaker Dark non-transparent helpers"
    * Restart Cura again
    Ā
    You should now have the same dark Cura theme, with the transparent helpers turned opaque.
    • Thanks 2
     Share
        Ā
        Ā
        Ā
        Ā
        Ā
        Ā
        Reliable bed tilt compensation (no more thumbscrews) 2.4 and 5 GHz Wi-Fi A 1080p camera (mounted higher for a better view) Compatibility with 280+ Marketplace materials Compatibility with S5 project files (no reslicing needed) And a whole lot more Ā
        • 12 replies
      • UltiMaker Cura 5.3.0-Alpha šŸŽ„ Tree Support Spotlight šŸŽ„
        Ā
        We generated a special version of Cura 5.2 called 5.3.0 Alpha + Xmas. The only changes we introduced compared to UltiMaker Cura 5.2.1 are those which are needed for the new supports. So keep in mind, this is not a sneak peek for Cura 5.3 (there are some really cool new features coming up) but a spotlight release highlighting this new version of tree supports. Ā
        • 17 replies
      • New here? Get ahead with a free onboarding course
        Ā
        Ultimaker S5 Pro Bundle, Ultimaker S5, Ultimaker S3 Ultimaker 2+ Connect.Ā  Ā
        They're ready for you on the Ultimaker Academy platform. All you need to do to gain access is to register your product to gain free access.Ā
        • 14 replies
