Posted · cura setting print temp to 230 for PLA
Hi 2nd post of the day, so thank you in advance of any help
Ultimaker 2 +
with latest firmware
cura 4..6.1
the printer is self is set for PLA wit a default hot end temp of 200 and 60 build plate
2.85mm filament etc pretty standard stuff
I normally print with .4mm nozzle but decided to change to .6mm to see what difference i can can achieve. and may be fix so other issues.
When cura slices a model using the parameters of generic PLA and .4mm nozzle. it would appear the the corresponding G code keeps / maintains a 200 degree hot end temp
when i change the Cura setting to allow for a .6mm nozzle it would appear that cura is overriding the printer default some how and settings the hot end temp to 230. While the PLA i am using seem to cope with this high temp it not right.
I am no g code expert but i think i would be expecting a "S" command to set temp and i can't see one in the code see below.
Even if i know what i was looking for i don't want to start editing g code.
so i am hoping its a Cura issue and can be fixed with a update or moving back to a earlier version
    Cura does not add temperature commands for "Ultimaker 2" gcode-flavor (a.k.a. UltiGCode).
    The material configuration on the printer includes temperature- and retraction settings for 5 different nozzle diameters. 230C is the default temperature for PLA and 0.6mm nozzle. You can adjust it there, if you want:
    Material -> Settings -> Customize -> Temperature
