Cura 4.6.1 will not slice
Dad003
Posted (edited) · Cura 4.6.1 will not slice
HI,
here my problem him trying to setup cura for double extrusion , when i merge the 2 part together i cannot ever slice them and get this and i cannot find what is the problem both part have been assigned to a different extruder . if i do not merge the piece together cura will slice them but when i tried to print them they are separate  from each other , the preview will show they are together
Merged
Not merged
Edited by Dad003
    Posted · Cura 4.6.1 will not slice
    okay i found out , i had deactivate extruder 1 in cura because when it export the Gcode it show as t0 but my machine as t1 and t2 , it mostly a bug from cura , extruder 1 wasnt selected but deactivate and causing cura to not slice , enabling it and switching to the right extruder 2-3 and it work thank you
