When Crown of Command is loaded into Cura, 2 items appear in the build space, the tower and, next to it, the crown, which is fitted to the tower top after printing. What I would like to do is print the crown alone. As they both load together from the same file is there any way to load only one item from an STL file which contains more than 1 item.
tinkergnome 927
5 hours ago, unclebill said:is there any way to load only one item from an STL file which contains more than 1 item
No, not while loading a file. But - as @loociano said - you can split the model into separate objects and delete the unwanted parts.
This can be done with third party software (like Blender or Meshmixer) or even with Cura, if you install the "Mesh Tools" plugin from the marketplace.
- 1
loociano 1
You could separate individual objects with the 3D software of your choice and export them individually in STL.
For example, in blender: https://blender.stackexchange.com/questions/6184/splitting-pieces-of-a-mesh-into-a-new-object
