No, single screen. I can drag and drop a file but if I try to open the file tab it crashes. Also crashes when I try to save a file. I have totally uninstalled and reinstalled, no joy.
On 6/13/2020 at 3:32 PM, ahoeben said:Do you have multiple displays? If so, does it matter which display Cura is on?
Just tried and it crashes, or hangs would be a better term, for me too if I have Cura on secondary display.
No issues while on display 1.
If I drag Cura to display one it release immedeately
- 9 months later...
Hi
I have the same issue with Cura 3D version 4.7 & 4.8. Opening a file or saving one freezes the application.
The issue doesn't occur when I launch the application by right clicking on the application and selecting 'run as an administrator'. As it is quite annoying, you can right click on the cura icon, select properties then go to the 'compatibility' tab and tick 'run this program as an administrator'.
I believe that is why you can't find any useful information in the Cura log files.
I hope this post helps someone.
cheers
- 5 months later...
I have the same problem. Windows 10. Cura previous versions were the same
Drag and drop or run as administrator get same crash.
So Cant use cura at all.
trace back
Traceback (most recent call last):
File "C:\Users\davep\AppData\Roaming\cura\4.10\plugins\CustomJobPrefix\CustomJobPrefix\PrintInformationPatches.py", line 120, in _triggerJobNameUpdate
self._updateJobName()
File "C:\Users\davep\AppData\Roaming\cura\4.10\plugins\CustomJobPrefix\CustomJobPrefix\PrintInformationPatches.py", line 129, in _updateJobName
base_name = self._print_information._stripAccents(self._print_information._base_name)
AttributeError: 'PrintInformation' object has no attribute '_stripAccents'
Logs
Thread 0x00004ec0 (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.10.0\plugins\USBPrinting\USBPrinterOutputDeviceManager.py", line 87 in _updateThread
File "threading.py", line 870 in run
File "threading.py", line 932 in _bootstrap_inner
File "threading.py", line 890 in _bootstrap
Thread 0x000029bc (most recent call first):
File "threading.py", line 306 in wait
File "zeroconf\__init__.py", line 2117 in wait
File "zeroconf\__init__.py", line 1434 in run
Thread 0x000020fc (most recent call first):
File "threading.py", line 558 in wait
File "C:\Program Files\Ultimaker Cura 4.10.0\plugins\UM3NetworkPrinting\src\Network\ZeroConfClient.py", line 81 in _handleOnServiceChangedRequests
Thread 0x00002034 (most recent call first):
File "zeroconf\__init__.py", line 1262 in run
Thread 0x00003ed8 (most recent call first):
File "zeroconf\__init__.py", line 1183 in run
Thread 0x00004e2c (most recent call first):
File "C:\Program Files\Ultimaker Cura 4.10.0\plugins\RemovableDriveOutputDevice\RemovableDrivePlugin.py", line 61 in _updateThread
Thread 0x00003b7c (most recent call first):
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\Backend\Backend.py", line 165 in _storeStderrToLogThread
Thread 0x00000674 (most recent call first):
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\Backend\Backend.py", line 153 in _storeOutputToLogThread
Thread 0x00000ef4 (most recent call first):
File "threading.py", line 302 in wait
File "threading.py", line 433 in acquire
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\JobQueue.py", line 98 in _nextJob
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\JobQueue.py", line 124 in run
Thread 0x00004624 (most recent call first):
Thread 0x000013dc (most recent call first):
Thread 0x00003b8c (most recent call first):
Thread 0x00000af0 (most recent call first):
Thread 0x00003c98 (most recent call first):
Thread 0x00001738 (most recent call first):
Thread 0x00000ff4 (most recent call first):
Thread 0x00004750 (most recent call first):
Thread 0x00000b20 (most recent call first):
Thread 0x00002f10 (most recent call first):
Thread 0x00001278 (most recent call first):
Thread 0x00000a04 (most recent call first):
Thread 0x00003bf8 (most recent call first):
Thread 0x00003294 (most recent call first):
Thread 0x00004dc4 (most recent call first):
Thread 0x00000da0 (most recent call first):
Thread 0x00002b78 (most recent call first):
Thread 0x0000286c (most recent call first):
Thread 0x00003450 (most recent call first):
Thread 0x00000b68 (most recent call first):
Thread 0x00002770 (most recent call first):
Thread 0x0000105c (most recent call first):
Thread 0x00003638 (most recent call first):
Current thread 0x00004ee0 (most recent call first):
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 396 in _logInfoWidget
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 182 in _createDialog
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 86 in __init__
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\bin\cura_app.py", line 159 in exceptHook
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\UI\PrintInformation.py", line 253 in _calculateInformation
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\UI\PrintInformation.py", line 169 in _onPrintDurationMessage
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\UI\PrintInformation.py", line 428 in setToZeroPrintInformation
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\UI\PrintInformation.py", line 441 in _onSceneChanged
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\CrashHandler.py", line 452 in _show
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\Event.py", line 218 in call
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\Qt\QtApplication.py", line 479 in event
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\CuraApplication.py", line 1088 in event
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\UM\Qt\QtApplication.py", line 393 in exec_
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\lib\python3.8\site-packages\cura\CuraApplication.py", line 865 in run
File "C:\Users\ultimaker\AppData\Local\Temp\cura-build-exe\build\inst\bin\cura_app.py", line 233 in <module>
File "Console.py", line 36 in run
File "__startup__.py", line 74 in run
Edited by WavyDavyadd logs
Check the Marketplace for an updated version of the Printjob Naming plugin.
1
Thanks Ambassador Thats solved it.
You are welcome New member. As a general rule, try to keep up to date with plugins. This particular issue was fixed with a plugin update 4 months ago.
1
ahoeben 1,760
