Thank you Illuminarti. Here is the gcode generated with default settings (quick print, normal quality):
https://dl.dropboxusercontent.com/u/2227139/wrong-R_Pi_Crust_bottom.gcode.zip
After, following your suggestions, I switched to expert settings and I used the 0.4 wall thickness. The generated gcode was printed without problems.
As I'm a really newbie, could you please look at this pictures:
As you can see, the right part of the robot (but in general of any printed object) is printed with a "lower resolution".
In the first image you can see that the layer being printed is bent.
Do you know how can I fix this problem?
Thank you in advance.
illuminarti 18
The STL file looks to be OK; Netfabb doesn't see any issues, and when I just try slicing it, it seemed to work ok. Can you http://mailto:gcode@fbrc8.com the broken gcode to take a look at?
