starting points out of control!
mariocoppola
Posted (edited) · starting points out of control!
Hi everybody,
I am experimenting a strange problem with starting points. I set the starting points to be nearest a precise point (-200, -200) but there some layers in which Cura seems to decide a starting point with an alien logic! Could someone help me with this?
Here is the pic with the settings and a white circle on the problem and attached you can find the 3mf file. The issue is happening from layer 2253 to 2263.
THANKS!!!!!!!
CFFFP_test.3mf
Edited by mariocoppola
    Posted · starting points out of control!
    This looks like a long standing bug (not mine, honest!) that has been woken from its slumber by a recent change I made to the wall print ordering. I have a fix which I am testing and, if that goes well, will submit to be included in a future release. A workaround is to disable the wall order optimization.
    • Thanks 1
