Problems with calibration?
Posted · Problems with calibration?
Most likely your short belts need tightening. Undo the four screws holding the stepper motors in place, push down fairly hard on the motor and screw the screws back in tight.
Also check that the set screws on your pullies are tight so that the pullies cannot move.
    It looks like retraction is not enabled. Check to make sure that there's a check box in "Enable retraction".
