Oh! It might matter how much you raised the model. You only raised it a very small amount. How much? Does it still do it if you raise the model 10mm?
As a programmer (not a cura programmer, not an ultimaker employee) it seems like thousands of times someone found a simple bug but I could not reproduce it. "just check this box". I did. Doesn't do it. "oh you have to raise it less than 1mm". Still doesn't do it. "oh you have to have this model with a curve on the bottom surface". Oh! Now it does it.
It's frustrating as a programmer when people think the bug is so simple to find and duplicate yet I know I've tested this exact "issue". It's just that it didn't occur to me to do something a different way.
So when the user puts in the extra effort of sending me the exact scenario, then I'm more likely to look at it. In your case that means either doing more testing or simply posting the 3mf file (in cura do "file" "save").
2
Sorry I didn't receive the notification email, I just saw your reply. Thanks for the time.
I also opened a GitHub issue.
Also since the model was not mine and one of my friends designed it I didn't have the permission to share that model.
gr5 1,838
You'd be very surprised! Often the model matters. See if it still does the problem with a cube.
