Posted · Does your PLA wire crack when bended?
I'm using the metal gray PLA wire that came with my UM. Once in a while it stops extruding and if i try to push the wire by hand i feel that it is stuck indeed.
I needed to pull it all out, cut half a meter and put it in again to make it work again.
It just happened again and i noticed that this piece that i had to cut away has the same diameter of the rest but it doesn't crack if i bend it. The rest of the roll instead breaks if i try to bend it.
Now i think that my extrusion problems are caused by the wire which must have some parts with different properties than the rest of the roll.
    I haven't had filament break during a print (red from UM, white and black from supply3dpla) but it will snap if I bend it sharply. I've also noticed that it sometimes cracks just as it enters the extruder if I've left it sitting for a few days.
    • 2 months later...
    we used to encounter this problem offen before, since the PLA propertise, we find and get solutions to deal , you can see our test printing video on http://i.youku.com/reprapPLA. we modify PLA ,did new formulation improve PLA toughness, bending not break .to make printing smoothly.
    you can download our instruction how to printing PLA correly from here:
    https://skydrive.live.com/redir?resid=CC8709D15BB78AA4!506&authkey=!AJrNhQC1vCR6vfw
