Thank you for the reply. I am using version 4.5 and I do not see the cutting mesh option. Is it available in version 4.5?
You probably know the answer! If you can't find the option, it isn't there! Why not upgrade to 4.6.1 version?
Got my printer printing perfect right now, just scared to change anything.
On 6/8/2020 at 11:19 PM, Cuq said:
I will give this a try again. I have a slightly related issue. I have my walls set to print at 80 mm/s. But when I go to the preview and check the feed rate, it shows much slower, around 15 mm/s.
I am currently using the Artillery Sidewinder printer. Someone made the profile for cura 4.5 that i am running. If I install 4.6, can I still us that printer profile?
thanks.
Cuq 162
Hello,
Cura 4.6.1
Condition 1 : You must use the option "Cutting Mesh" for the Modify settings overlaps function and not
Infill mesh onlyCondition 2 : As you have already fixed some values for the speeds you must change each individual speed values and not only the global Print Speed value.
Condition 3 : If your part is small don't forget that the cooling settings : Minimum Layer Time and Minimum Speed can limite your print speed.
