22 hours ago, JohnInOttawa said:I may have found an answer, as I thought about the last line and editing G-code, which led me to post processing options where I found the experimental ChangeatZ script. Is this the recommended solution? If so, I'd appreciate thoughts on what worked or didn't with it.
Cheers
John
I have been using this. It seems to work pretty well but will kick out an ER999 code so just know that is what it is from.
- 1
JohnInOttawa 104
Cheers
John
