That is correct, UM3.
So Cura Connect is just the device web page. OK.
Thanks.
I guess for me the page on Cura Connect on the Ultimaker home page was more confusing than helpful.
Thanks.
Yeah the naming has confused a lot of people (even internally 😜)
It's a firmware feature, so if your UM3 is up to date, it will be on there. Just navigate to the IP of your printer to access it.
Enigma_M4 76
regarding to your recent posts, you use an UM3?
Ultimaker Connect (formerly called "Cura Connect") is implemented in the firmware of the UM3 and the S series, so there's no need to download anything (except of using the actual firmware or, for the UM3, at least 4.3.3).
To enter Ultimaker Connect, you just have to enter the internal IP adress of your network-connected printer in your browser.
Regards
