Pause at Layer, filament change probs
barking_spider
Posted · Pause at Layer, filament change probs
I'm using 4.6.1 and a Creality Ender 3. When I try to use Pause at Layer (to make a filament change), it initially works fine.
After the pause, it goes to z0 and drags the hot end through the previously printed layers. Not nominal! I've tried it multiple times, same results. I was following CHEP's video, https://www.youtube.com/watch?v=1nBnVtOEAiY , and it seems that in the Comments section others are also having problems.
Maybe I need to downgrade the version?
