Ultima 2 extended +, tolerances and surface finishes help
gr5 2,243
Ultimaker published some "engineering" settings for S3 and S5. Here is a summary of what you do to get your parts as close to tolerance as possible:
Line width: 0.4
Wall thickness: 1.2
Top/Bottom thickness: 1.2
Speeds: 35-40 (all speeds, except travel)
Jerks: 20
Horizontal expansion: -0.03
walls: 3
Inital Layer Height = 0.1
Slicing Tolerance = Exclusive
Combing Mode = off
Outer before Inner Walls = Checked
