Posted · Holes on print
Is there a Cura setting to get rid of the ugly line, its caused by the slicer acting in weird ways. when printting with a nozzle larger than 0.6mm, thios print is on a 1.2mm nozzle.
Coasting makes it worse.
When printting the walls the end of tool path does not connect with the beginning.
A picture example.
This causes the parts to be unuseable when made with larger nozzles, and sometimes its get more funky when the seams align and it makes a hole that leads straight tru the wall.
Would not mind a seam that i would sand down, unfortunately you cant sand holes smaller.
Material used makes no difference,
parts in the picture are printed in Formfutura ApolloX at 255°C Nozzle 95°C bed, 50°C Chamber, 12-24mm/s Speed.
