yes it is already the third one that I have been going on for about 18 months so I was trying to understand what I could put on because the plates did not last long or it will be their defect ... I was trying new alternatives because it is not coming cheap .
ultimaker 2
Sounds strange and is not normal. Are you sure you bought an original replacement board and not something from China?
Smithy 791
The best way is to replace the damaged board with an original replacment part. There is no board on Amazon you can use just out of the box. If you use a 3rd Party board, you wil get a different system/printer and you have to take care about all settings steppers configuration and so on.
