Regarding your first question, I guess you have the possibility to override the material when you load it. But I am not sure, have never tried it myself. But keep in mind that you should take a material which is close to the UM ToughPLA, otherwise your object is maybe not strong enough.
The PVA problem is 99% a problem of humidity and that your PVA has absorbed too much moisture. You should always keep the spool in a drybox or airtight bag when not printing and if you print a long job you should also consider to buy a Polybox or something like that, to keep the spool dry also during printing. PVA is very sensitive against high humidity and gets soft very quickly.
But you can save your PVA spool and dry it again. Put the spool on the heated bead, cover it with a towel or cardbox and leave it there over night.
Smithy 1,145
Hi
