5 hours ago, maht said:Can you give some more details about your setup?
ty for answering....
while I was writing the answer I understood what was wrong ... I always thought that the origin of the axes (green circle) was what "cura" thought was the home point ... when in reality it is only a "visual effect" and not influencing on nothing 😅...mirrored prints must have another reason 😬
Guest maht
Can you give some more details about your setup? Is the origin intended to be in the rear corner, or did you configure this in firmware? This could be something that can be fixed in firmware/stepper motor wiring.
