That (horizontal)_ offset is "by design" and should not affect printing larger models. The offset is there because the nozzle is not in the middle of the printhead.
1
7 minutes ago, ahoeben said:That (horizontal)_ offset is "by design" and should not affect printing larger models. The offset is there because the nozzle is not in the middle of the printhead.
OK, Thanks!
ahoeben 1,968
How big of an offset are we talking about?
In the Machine Settings, is the "Origin at center" box ticked? It should NOT be ticked.
basteluwe 1
Hi there, thanks for answering.
The offset is for the X-Axis: 10 mm to the right, Y-Axis: 2.5 mm to the back (about).
Yes, the checkbox "Origin at center" is un-checked (empty).
BUT: I just got an idea, what could have caused the offset. Some time ago I checked the accuracy of measures of my prints and found them slightly to small. So I increased the "Steps per Unit" for all axis.
Original values were: M92 X78.74 Y78.74 Z200.00 E836.00
New values are: M92 X79.38 Y79.86 Z200.00 E854.00
I guess by changing the "Steps per Unit" I have messed with the center-position as well, right?
