Opening a 3MF file across Windows and Mac
ArturDB
Posted · Opening a 3MF file across Windows and Mac
Hello!
Using Cura on my Windows notebook, I saved a .3mf file with all information such as printer profile and print settings. I tried to open it in my Macbook and it didn't import project info, just the 3D model. To test if the problem was my Mac or the file itself, I reinstalled Cura on Windows, without any previous settings and opened this .3mf file. All project settings were loaded properly along with the 3d file.
Then, using Cura on my Mac I saved another .3mf project and opened it on my Windows and it also worked fine.
I use Cura version 4.6.`1 in both computers.
Why isn't my Mac opening .3mf files properly?
SavedOnWindows.3mf SavedOnMac.3mf
    Check the settings on your Mac Cura, how you want to open project files. There is a setting to just import the model, open as project or ask every time. It seems you have the setting at import just the model.
    • Thanks 1
    That's exactly what it was, so easy.. thank you!!!
        • 26 replies
