Clevis 6_25mm.stl Here is the file
When you exported the file after your change the settings inCura, did you change the extension of the file for .STL?
The attached file does not look like a STL file. The file size is rather small.
The contents of that file are:
MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH-MESH
@Framar is right, it's not an STL file.
It worked one time and then I adjusted the size in FreeCAD, which is where I drew it, and exported again.
burtoogle 505
Could you please attach the stl file to this thread, thanks.
