Printer Bed Visibility Settings in Cura
awilliamspvi
Posted (edited) · Printer Bed Visibility Settings in Cura
When using Cura configured for the S5 printer (and I assume similarly for other Ultimaker products), a rendering of the S5 build plate and surrounding features are surrounding the build volume. See attached image. Is there a setting on Cura to remove this rendering so that the only thing visible is the build volume and the bottom grid?image.thumb.png.6f51b844642cf7a1c087cd041bc654ef.png
Edited by awilliamspvi
    Posted · Printer Bed Visibility Settings in Cura
    Not if you use the Ultimaker S5 definition and profiles.
    You could edit the ultimaker_s5.def.json file to remove the `        "platform": "ultimaker_s5_platform.obj",`   line, but you would have to do that again when you install a new version of Cura.
    Also: why?
        • 30 replies
