Thank you Carla. That worked. In Windows the path is C:\Program Files\Ultimaker Cura 4.6\resources\images
1
No problem, happy it worked and thanks for posting the windows path incase anyone else as same problem.
Carla_Birch 115
Not sure the path root for it on windows, but on Mac you can remove the png image from the install folder of Cura whats in "Contents" - "Resources" - "Resources" - "Images" and remove "anycubic-chiron.png".
Besure to restart Cura after and the image will be gone 🙂
