Posted (edited) · Inclination
At first I thought that this happens due to printer's mechanical fault - even changed X and Y motors
Inclination continued on Y axis
But then I rotated the model on 90 degrees in Cura and produced new GCode - inclination happens on X axis
So - it is Cura's wrong code issue - same STL (made on Solidworks) is Ok printed on Simplify3D G-code
But - I prefer Cura !
I also imported model from SolidWork file using Cura pugin - the same inclination
Edited by Nail
    Posted · Inclination
    The cura gcode uses 150 mm/S for the travel speed, the S3D code uses 80 mm/S. Try using the same speed in Cura.
    Just printed 2 models, one with 45 degrees rotations
    Both stand vertical. Travel speed - 200 mm/s
    But - this models are 'empty', 0% filling, so only shells
    Next time I will try with less travel speed. Maybe alot of fast pulls/pushes shift cheap printer's mechanic
    It happens in less wide side, where accelerarions are more high
    Edited by Nail
    Here is the plan view of the Gcode file in Nail's second post (read into autocad as a wireframe).  It looks square from any direction.
    with such slow motions - no inclination
    thanns
    Good.
