Posted (edited) · Settings in exported gcode name or to octoprint
I find myself sometimes doing tests where I vary the fan speed or temperature and then send the print to octoprint.  I have to remember to name each file something different when I do that so that I don't accidentally overwrite a previous generated gcode.  It would be great to be able to put settings into the name as variables similar to the below where the variable setting is 2 underscores, setting name, and then 2 underscores.
SimpleBox-ET__EXTRUDERTEMP__-FanSpeed__FANSPEED__
When the gcode is exported or sent to octoprint, the name would be
SimpleBox-ET205-FanSpeed100.gcode
I can dream anyway 🙂
Edited by Adam324
    I think you can do that with a small modification of the @ahoeben custom printjob naming  plugin. Perhaps you could ask him to add in the list of the available parameters these two options..  https://github.com/fieldOfView/Cura-CustomJobPrefix
    You just need to add two lines in the PrintInformationPatches.py file in the relacement section :
                "{material_print_temperature}": self._abbreviate_number(extruder_stack.getProperty("material_print_temperature", "value")),
                "{cool_fan_speed}": self._abbreviate_number(extruder_stack.getProperty("cool_fan_speed", "value")),
    Edited by Cuq
