Ah ok I found the issue!! I had set a hole offset of +0.45mm to accomodate for the holes. Apparently Cura assumes that the whole floor area is a big hole(!) thus adjusting everything inside to +0.45mm.
The problem is that if you check my file, not everything is getting slimmer due to the hole setting, which is strange...
Is there a setting to adjust the starting layer for identifying the holes? Or something where I select the maximum size a hole must have before adding the extra hole offset?
Otherwise if I create a big barrel to store my pencils, it will still add +0.45mm to that one.
Edited by agiorgitis
nallath 1,125
Please also share the model (preferably in a project file, that way we also have your setup available!)
agiorgitis 0
Sure, here is the file!
Seems quite strange, I have printed maybe 200 other parts, but this is the first time I come into such an issue...
4.6 and 4.6.2 both behave like that.
box.3mf
