For the Bowden tube slipping out of the feeder, check that the tube coupling collet (the round item that you push the Bowden into) as all its teeth still so it can grip the bowden.
If the coupling collet is all fine then cut around 4mm off the end of the Bowden tube, this will mean the coupling collet will now be gripping a fresh part of the Bowden tube as it’s likely that where it gripped before if worn and that’s why the Bowden tube was able to slip free from the feeder.
Thank you so much for the comments.
I will take that action as security. When printing starts the tube is perfectly anchored with force and it is difficult to move from its position
Carla_Birch 116
Smithy 1,145
Brancusi 0
