UM 2 mirrored x axis movement
jeson
Posted (edited) · UM 2 mirrored x axis movement
After printing and starting a new print, no changes made what so ever to the printer, not even changed the material, the printer started to print on the right hand side of the table instead of on the left hand side where I had put the object. It also made a lot of noise when moving the head to the farthest right hand side.
I did a factory reset and updated the firmware through Cura, but the problem remains.
I tried to print but found that the table is now in a lower position than it should.
Any hints?
Edited by jeson
