I have no experience with the mould-option. But why not make the mould yourself in CAD? Then you have all the freedom you want, and you can insert any desired features.
- Draw a box around your model.
- Subtract the model from the box, so you have a hollow (mould) shape of the model.
- Provide pouring openings and funnels.
- Provide venting openings for air to escape.
- Provide flanges or screw-openings to assemble and clamp both mould halves later on.
- Design a thin plate and provide alignment features on the edges it: blobs on one side, pits on the other.
- Use that thin plate to cut the mould in two halves. So both halves of the mould will align correctly later on, thanks to the blobs on one side, and pits on the other.
- Print both mould halves on their back. That is the advantage of using a box to start from: then you end up with two halves with a flat backside, easy to print. Print with wall-thickness and support-density as required for your castings. Concrete and gypsum will need stronger parts than foams, obviously.
- Spray the mould with suitable mould-release spray for your materials. Then spray again.
- Clamp both halves together, and ready to go.
Then you have a professional 3D-printed mould. Very similar to hand-made moulds. All these features are very difficult to generate automatically; you can design them better manually.
Watch out for exothermic casting materials (even gypsum): they might melt the mould. Use slow-curing or non-exothermic materials.
geert_2 558
