Posted · Can't slice tolerance.stl file
I currently have Cura 4.6.2 and a Aorus 7 gaming laptop.
I wanted to test out the tolerances on my printer after the profile changes I've made with this file on Thingiverse (The STL file is attached to this thread)
https://www.thingiverse.com/thing:2318105
But when I import it into Cura and click slice, nothing happens and the slicing progress bar doesn't budge.
I've re-installed Cura like four times now, deleted all the associated files from my 'AppData' folder and anywhere else the Cura files could have been, and so far no luck
I've checked the Windows firewall incase if an exception wasn't made for Cura and that checked out okay.
Any advice/recommendations would be appriciated
tolerance_test.stl
    Have you tried both of these methods?
    https://support.ultimaker.com/hc/en-us/articles/360013007080-How-can-I-completely-reset-my-Ultimaker-Cura-installation-
    I'd also check your graphics drivers are updated, and that your laptop is using the GPU, not onboard graphics.
    Also check that red icon over the tools in your image, you might have old plugins interfering.
    I’ve tried those methods twice so far and it didn’t help
    But since you mentioned about the GPU, how do I check that on Cura? I know for a fact that my graphics drivers are up to date
    We can't tell what is going on without looking at the logs. See Help->Show configuration folder. The file you are looking for is called "cura.log".
    I noticed the EngineErrorThread debug message here
    2020-07-30 03:29:36,815 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [844]: Backend quit with return code 3221225477. Resetting process and socket.
    2020-07-30 03:29:37,059 - INFO - [MainThread] UM.Backend.Backend._onSocketError [214]: Backend crashed or closed.
    2020-07-30 03:29:37,061 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first.
    2020-07-30 03:29:37,063 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Attempting to kill the engine process
    2020-07-30 03:29:37,066 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first.
    2020-07-30 03:29:37,070 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [184]: Socket state changed to Listening
    2020-07-30 03:29:37,082 - INFO - [MainThread] UM.Backend.Backend.startEngine [86]: Started engine process: C:\Program Files\Ultimaker Cura 4.6\CuraEngine.exe
    2020-07-30 03:29:37,085 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [106]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.6\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2020-07-30 03:29:37,119 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,121 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] Cura_SteamEngine version 4.6.2
    2020-07-30 03:29:37,123 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] Copyright (C) 2019 Ultimaker
    2020-07-30 03:29:37,125 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,128 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] This program is free software: you can redistribute it and/or modify
    2020-07-30 03:29:37,131 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Connected
    2020-07-30 03:29:37,133 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [177]: Backend connected on port 49674
    2020-07-30 03:29:37,134 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2020-07-30 03:29:37,137 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2020-07-30 03:29:37,139 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] (at your option) any later version.
    2020-07-30 03:29:37,141 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,143 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] This program is distributed in the hope that it will be useful,
    2020-07-30 03:29:37,145 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2020-07-30 03:29:37,147 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2020-07-30 03:29:37,149 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] GNU Affero General Public License for more details.
    2020-07-30 03:29:37,151 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,153 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] You should have received a copy of the GNU Affero General Public License
    2020-07-30 03:29:37,155 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    And the rest of the log file
    2020-07-30 03:20:46,867 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
    2020-07-30 03:20:46,897 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
    2020-07-30 03:20:46,914 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
    2020-07-30 03:20:46,929 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
    2020-07-30 03:20:46,944 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
    2020-07-30 03:20:46,962 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
    2020-07-30 03:20:46,995 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
    2020-07-30 03:20:47,011 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
    2020-07-30 03:20:47,035 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
    2020-07-30 03:20:47,053 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
    2020-07-30 03:20:47,068 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
    2020-07-30 03:20:47,080 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
    2020-07-30 03:20:47,105 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
    2020-07-30 03:20:47,121 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
    2020-07-30 03:20:47,136 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
    2020-07-30 03:20:47,158 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
    2020-07-30 03:20:47,176 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
    2020-07-30 03:20:47,191 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
    2020-07-30 03:20:47,205 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
    2020-07-30 03:20:47,230 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
    2020-07-30 03:20:47,244 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
    2020-07-30 03:20:47,283 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
    2020-07-30 03:20:47,304 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
    2020-07-30 03:20:47,325 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
    2020-07-30 03:20:47,344 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
    2020-07-30 03:20:47,423 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:20:47,425 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:20:47,426 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:20:47,428 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:20:47,430 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:20:47,432 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:20:47,434 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:20:47,436 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:20:47,441 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
    2020-07-30 03:20:47,457 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
    2020-07-30 03:20:47,477 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
    2020-07-30 03:20:47,501 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
    2020-07-30 03:20:47,524 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
    2020-07-30 03:20:47,539 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
    2020-07-30 03:20:47,561 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
    2020-07-30 03:20:47,577 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
    2020-07-30 03:20:47,597 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
    2020-07-30 03:20:47,618 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
    2020-07-30 03:20:47,637 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
    2020-07-30 03:20:47,882 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
    2020-07-30 03:20:47,907 - INFO - [Thread-1] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
    2020-07-30 03:20:47,909 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
    2020-07-30 03:20:48,256 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
    2020-07-30 03:20:48,426 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
    2020-07-30 03:20:48,483 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
    2020-07-30 03:20:48,543 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
    2020-07-30 03:20:48,615 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
    2020-07-30 03:20:48,701 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
    2020-07-30 03:20:48,762 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
    2020-07-30 03:20:48,807 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
    2020-07-30 03:20:48,854 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
    2020-07-30 03:20:48,913 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
    2020-07-30 03:20:48,930 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
    2020-07-30 03:20:48,947 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
    2020-07-30 03:20:48,966 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
    2020-07-30 03:20:48,983 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
    2020-07-30 03:20:48,999 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
    2020-07-30 03:20:49,016 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
    2020-07-30 03:20:49,032 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
    2020-07-30 03:20:49,050 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
    2020-07-30 03:20:49,065 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
    2020-07-30 03:20:49,086 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
    2020-07-30 03:20:49,117 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
    2020-07-30 03:20:49,133 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
    2020-07-30 03:20:49,136 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [374]: Loading all plugins took 3.0347068309783936 seconds
    2020-07-30 03:20:49,146 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [160]: Looking for old configuration files to upgrade.
    2020-07-30 03:20:49,150 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,152 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,155 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,156 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,156 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,173 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,175 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,178 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,180 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,182 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,184 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,187 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,189 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,191 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,194 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,196 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,198 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,200 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,203 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,205 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,208 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,209 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,213 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,215 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:20:49,217 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:20:49,222 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [226]: The preferences file cannot be found or it is corrupted, so we will use default values
    2020-07-30 03:20:49,224 - INFO - [MainThread] UM.Qt.QtApplication.startSplashWindowPhase [235]: The preferences file 'None' cannot be found, will use default values
    2020-07-30 03:20:57,793 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [360]: Loading metadata into container registry took 8.463564395904541 seconds
    2020-07-30 03:20:57,912 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [111]: Select build plate: 0
    2020-07-30 03:20:57,915 - INFO - [MainThread] cura.CuraApplication.run [751]: Initializing machine error checker
    2020-07-30 03:20:57,918 - INFO - [MainThread] cura.CuraApplication.run [756]: Initializing machine manager
    2020-07-30 03:20:57,921 - INFO - [MainThread] cura.CuraApplication.run [761]: Initializing container manager
    2020-07-30 03:20:58,166 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2020-07-30 03:20:58,190 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light\theme.json
    2020-07-30 03:20:59,095 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [231]: Loaded theme C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light
    2020-07-30 03:21:00,832 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [311]: Creating post processing plugin view.
    2020-07-30 03:21:00,843 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: BQ_PauseAtHeight
    2020-07-30 03:21:00,852 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ChangeAtZ
    2020-07-30 03:21:00,864 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ColorMix
    2020-07-30 03:21:00,871 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2020-07-30 03:21:00,876 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayRemainingTimeOnLCD
    2020-07-30 03:21:00,881 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: FilamentChange
    2020-07-30 03:21:00,886 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: InsertAtLayerChange
    2020-07-30 03:21:00,892 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeight
    2020-07-30 03:21:00,897 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet
    2020-07-30 03:21:00,904 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightforRepetier
    2020-07-30 03:21:00,911 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: RetractContinue
    2020-07-30 03:21:00,918 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: SearchAndReplace
    2020-07-30 03:21:00,926 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: Stretch
    2020-07-30 03:21:00,931 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: TimeLapse
    2020-07-30 03:21:00,936 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: UsePreviousProbeMeasurements
    2020-07-30 03:21:01,244 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [321]: Post processing view created.
    2020-07-30 03:21:01,401 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:21:01,403 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:21:01,405 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:21:02,883 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Dialogs/WorkspaceSummaryDialog.qml:146: TypeError: Cannot read property 'extruderList' of null
    2020-07-30 03:21:02,885 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/PrintSetupSelector/Custom/CustomPrintSetup.qml:76:29: Unable to assign null to double
    2020-07-30 03:21:02,894 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2020-07-30 03:21:03,000 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:21:03,003 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:143: TypeError: Cannot read property 'hasRemoteConnection' of null
    2020-07-30 03:21:03,031 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:47: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:21:03,033 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:118: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:21:03,035 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
    2020-07-30 03:21:03,037 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
    2020-07-30 03:21:03,039 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:247: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:21:03,041 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:308: TypeError: Cannot read property 'hasVariants' of null
    2020-07-30 03:21:03,043 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:35: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:21:03,108 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2020-07-30 03:21:03,111 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [111]: Creating model checker view.
    2020-07-30 03:21:03,123 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [120]: Model checker view created.
    2020-07-30 03:21:03,123 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [71]: Creating dialog [MoreInfoWindow.qml]
    2020-07-30 03:21:03,156 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [542]: Requesting [updates] metadata from server.
    2020-07-30 03:21:03,159 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [112]: No auth data to retrieve the access_token from
    2020-07-30 03:21:03,160 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
    2020-07-30 03:21:03,166 - DEBUG - [MainThread] cura.CuraApplication.run [799]: Booting Cura took 17.917574167251587 seconds
    2020-07-30 03:21:03,171 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._processRequest [346]: Request [d48203f9d6a040948a7d7682511b1ba2] started
    2020-07-30 03:21:03,174 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:21:03,180 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:21:03,182 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [75]: No active GlobalStack, set quality profile model as empty.
    2020-07-30 03:21:03,184 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:21:03,185 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [39]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
    2020-07-30 03:21:13,158 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
    2020-07-30 03:25:04,139 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
    2020-07-30 03:25:04,150 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
    2020-07-30 03:25:04,158 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
    2020-07-30 03:25:04,165 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
    2020-07-30 03:25:04,172 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
    2020-07-30 03:25:04,179 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
    2020-07-30 03:25:04,194 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
    2020-07-30 03:25:04,201 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
    2020-07-30 03:25:04,213 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
    2020-07-30 03:25:04,220 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
    2020-07-30 03:25:04,228 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
    2020-07-30 03:25:04,237 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
    2020-07-30 03:25:04,245 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
    2020-07-30 03:25:04,252 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
    2020-07-30 03:25:04,260 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
    2020-07-30 03:25:04,268 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
    2020-07-30 03:25:04,277 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
    2020-07-30 03:25:04,284 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
    2020-07-30 03:25:04,291 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
    2020-07-30 03:25:04,301 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
    2020-07-30 03:25:04,308 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
    2020-07-30 03:25:04,327 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
    2020-07-30 03:25:04,338 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
    2020-07-30 03:25:04,348 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
    2020-07-30 03:25:04,357 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
    2020-07-30 03:25:04,391 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:25:04,393 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:25:04,395 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:25:04,398 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:25:04,400 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:25:04,402 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:25:04,404 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:25:04,406 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:25:04,413 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
    2020-07-30 03:25:04,423 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
    2020-07-30 03:25:04,432 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
    2020-07-30 03:25:04,444 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
    2020-07-30 03:25:04,457 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
    2020-07-30 03:25:04,465 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
    2020-07-30 03:25:04,476 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
    2020-07-30 03:25:04,485 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
    2020-07-30 03:25:04,497 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
    2020-07-30 03:25:04,506 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
    2020-07-30 03:25:04,515 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
    2020-07-30 03:25:04,617 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
    2020-07-30 03:25:04,625 - INFO - [Thread-1] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
    2020-07-30 03:25:04,628 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
    2020-07-30 03:25:04,975 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
    2020-07-30 03:25:05,149 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
    2020-07-30 03:25:05,205 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
    2020-07-30 03:25:05,260 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
    2020-07-30 03:25:05,320 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
    2020-07-30 03:25:05,382 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
    2020-07-30 03:25:05,442 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
    2020-07-30 03:25:05,504 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
    2020-07-30 03:25:05,546 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
    2020-07-30 03:25:05,610 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
    2020-07-30 03:25:05,635 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
    2020-07-30 03:25:05,647 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
    2020-07-30 03:25:05,657 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
    2020-07-30 03:25:05,666 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
    2020-07-30 03:25:05,675 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
    2020-07-30 03:25:05,682 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
    2020-07-30 03:25:05,689 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
    2020-07-30 03:25:05,696 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
    2020-07-30 03:25:05,703 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
    2020-07-30 03:25:05,715 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
    2020-07-30 03:25:05,730 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
    2020-07-30 03:25:05,738 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
    2020-07-30 03:25:05,740 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [374]: Loading all plugins took 2.132829427719116 seconds
    2020-07-30 03:25:05,749 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [160]: Looking for old configuration files to upgrade.
    2020-07-30 03:25:05,755 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,757 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,761 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,764 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,767 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,769 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,773 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,777 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,781 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,785 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,792 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,796 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,799 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,801 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,804 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,806 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,809 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,812 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,815 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,817 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,820 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,823 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,826 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,828 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,831 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,833 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,837 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,840 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:05,843 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:25:05,845 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:25:15,156 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [360]: Loading metadata into container registry took 9.20497989654541 seconds
    2020-07-30 03:25:15,299 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [111]: Select build plate: 0
    2020-07-30 03:25:15,302 - INFO - [MainThread] cura.CuraApplication.run [751]: Initializing machine error checker
    2020-07-30 03:25:15,304 - INFO - [MainThread] cura.CuraApplication.run [756]: Initializing machine manager
    2020-07-30 03:25:15,307 - INFO - [MainThread] cura.CuraApplication.run [761]: Initializing container manager
    2020-07-30 03:25:15,381 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2020-07-30 03:25:15,403 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light\theme.json
    2020-07-30 03:25:15,626 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [231]: Loaded theme C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light
    2020-07-30 03:25:16,654 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [311]: Creating post processing plugin view.
    2020-07-30 03:25:16,658 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: BQ_PauseAtHeight
    2020-07-30 03:25:16,660 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ChangeAtZ
    2020-07-30 03:25:16,662 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ColorMix
    2020-07-30 03:25:16,663 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2020-07-30 03:25:16,664 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayRemainingTimeOnLCD
    2020-07-30 03:25:16,665 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: FilamentChange
    2020-07-30 03:25:16,666 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: InsertAtLayerChange
    2020-07-30 03:25:16,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeight
    2020-07-30 03:25:16,669 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet
    2020-07-30 03:25:16,671 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightforRepetier
    2020-07-30 03:25:16,672 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: RetractContinue
    2020-07-30 03:25:16,673 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: SearchAndReplace
    2020-07-30 03:25:16,676 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: Stretch
    2020-07-30 03:25:16,677 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: TimeLapse
    2020-07-30 03:25:16,678 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: UsePreviousProbeMeasurements
    2020-07-30 03:25:16,814 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [321]: Post processing view created.
    2020-07-30 03:25:16,904 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:25:16,907 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:25:16,911 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:25:18,166 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Dialogs/WorkspaceSummaryDialog.qml:146: TypeError: Cannot read property 'extruderList' of null
    2020-07-30 03:25:18,169 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/PrintSetupSelector/Custom/CustomPrintSetup.qml:76:29: Unable to assign null to double
    2020-07-30 03:25:18,177 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2020-07-30 03:25:18,239 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:25:18,243 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:143: TypeError: Cannot read property 'hasRemoteConnection' of null
    2020-07-30 03:25:18,263 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:47: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:25:18,266 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:118: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:25:18,269 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
    2020-07-30 03:25:18,271 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
    2020-07-30 03:25:18,274 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:247: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:25:18,276 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/CustomConfiguration.qml:308: TypeError: Cannot read property 'hasVariants' of null
    2020-07-30 03:25:18,278 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/Menus/ConfigurationMenu/ConfigurationMenu.qml:35: TypeError: Cannot read property 'hasMaterials' of null
    2020-07-30 03:25:18,312 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2020-07-30 03:25:18,313 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [111]: Creating model checker view.
    2020-07-30 03:25:18,318 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [120]: Model checker view created.
    2020-07-30 03:25:18,319 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [71]: Creating dialog [MoreInfoWindow.qml]
    2020-07-30 03:25:18,345 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [542]: Requesting [updates] metadata from server.
    2020-07-30 03:25:18,349 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [112]: No auth data to retrieve the access_token from
    2020-07-30 03:25:18,351 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
    2020-07-30 03:25:18,357 - DEBUG - [MainThread] cura.CuraApplication.run [799]: Booting Cura took 15.337218284606934 seconds
    2020-07-30 03:25:18,362 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._processRequest [346]: Request [ecfab21fcb3940329106049244343bbf] started
    2020-07-30 03:25:18,365 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:25:18,368 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:25:18,370 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [75]: No active GlobalStack, set quality profile model as empty.
    2020-07-30 03:25:18,373 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:25:18,375 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [39]: No active GlobalStack, set CustomQualityProfilesDropDownMenuModel as empty.
    2020-07-30 03:25:18,719 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [207]: Support for Vertex Array Objects: True
    2020-07-30 03:25:18,735 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2020-07-30 03:25:18,739 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 26.20.100.7324
    2020-07-30 03:25:18,741 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2020-07-30 03:25:18,745 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) UHD Graphics 630
    2020-07-30 03:25:18,747 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2020-07-30 03:25:18,749 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:25:18,766 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\selection.shader]...
    2020-07-30 03:25:18,780 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\select_face.shader]...
    2020-07-30 03:25:18,794 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:25:18,805 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\composite.shader]...
    2020-07-30 03:25:18,825 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\overhang.shader]...
    2020-07-30 03:25:18,846 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\striped.shader]...
    2020-07-30 03:25:18,865 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\transparent_object.shader]...
    2020-07-30 03:25:18,880 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\striped.shader]...
    2020-07-30 03:25:18,895 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray.shader]...
    2020-07-30 03:25:18,908 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray_composite.shader]...
    2020-07-30 03:25:18,943 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\platform.shader]...
    2020-07-30 03:25:18,980 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray.shader]...
    2020-07-30 03:25:19,636 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestFinished [408]: Request [ecfab21fcb3940329106049244343bbf] finished.
    2020-07-30 03:25:19,638 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:25:22,637 - INFO - [MainThread] cura.CuraApplication.writeToLog [570]: User accepted the User-Agreement.
    2020-07-30 03:25:32,644 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
    2020-07-30 03:25:35,435 - INFO - [MainThread] cura.Settings.MachineManager.addMachine [358]: Trying to add a machine with the definition id [creality_ender3]
    2020-07-30 03:25:35,676 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [286]: The definition cache for definition creality_ender3 failed to pickle.
    2020-07-30 03:25:36,088 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [106]: Adding container tree for creality_ender3 took 0.37100768089294434 seconds.
    2020-07-30 03:25:36,222 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [184]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3] at position [0]
    2020-07-30 03:25:36,224 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x000002B77C41E510> is deprecated (since 4.4): Please use extruderList instead.
    2020-07-30 03:25:36,227 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_ender3]
    2020-07-30 03:25:36,457 - WARNING - [MainThread] LocalContainerProvider.LocalContainerProvider._saveCachedDefinition [286]: The definition cache for definition creality_base failed to pickle.
    2020-07-30 03:25:36,504 - WARNING - [MainThread] cura.Settings.GlobalStack.addExtruder [179]: Extruder [creality_base_extruder_0 #2] has already been added to this stack [Creality Ender-3]
    2020-07-30 03:25:36,506 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [156]: Extruder [creality_base_extruder_0 #2] has already been registered on machine [Creality Ender-3], not doing anything
    2020-07-30 03:25:36,508 - INFO - [MainThread] UM.Logger.info [122]: Initializing Active Machine...
    2020-07-30 03:25:36,580 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:25:36,621 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:25:36,624 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:25:36,629 - INFO - [Thread-3] STLReader.STLReader.load_file [52]: Using NumPy-STL to load STL data.
    2020-07-30 03:25:36,673 - DEBUG - [Thread-3] UM.Mesh.MeshData.calculateNormalsFromVertices [548]: Calculating normals took 0.0 seconds
    2020-07-30 03:25:36,674 - DEBUG - [Thread-3] STLReader.STLReader._read [104]: Loaded a mesh with 8520 vertices
    2020-07-30 03:25:37,014 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [135]: New error check scheduled.
    2020-07-30 03:25:37,123 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:25:37,127 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:25:37,193 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [74]: No machine with name Creality Ender-3 in list of firmware to check.
    2020-07-30 03:25:37,257 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:25:37,267 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\grid.shader]...
    2020-07-30 03:25:37,327 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:25:37,331 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:25:37,997 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [187]: Error check finished, result = False, time = 1.0s
    2020-07-30 03:25:45,437 - INFO - [Thread-4] STLReader.STLReader.load_file [52]: Using NumPy-STL to load STL data.
    2020-07-30 03:25:45,759 - DEBUG - [Thread-4] UM.Mesh.MeshData.calculateNormalsFromVertices [548]: Calculating normals took 0.1296525001525879 seconds
    2020-07-30 03:25:45,793 - DEBUG - [Thread-4] STLReader.STLReader._read [104]: Loaded a mesh with 4670010 vertices
    2020-07-30 03:25:46,641 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
    2020-07-30 03:25:46,816 - DEBUG - [Thread-4] UM.Mesh.MeshData.approximateConvexHull [503]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 1.0129852294921875 seconds. 6444 input vertices. 6444 output vertices.
    2020-07-30 03:25:47,403 - DEBUG - [Thread-4] UM.FileHandler.ReadFileJob.run [71]: Loading file took 2.0 seconds
    2020-07-30 03:25:48,384 - DEBUG - [Thread-4] UM.Mesh.MeshData.approximateConvexHull [503]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.9778611660003662 seconds. 6443 input vertices. 6443 output vertices.
    2020-07-30 03:25:48,409 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x000002B70DCB3048>, took 0ms
    2020-07-30 03:25:48,813 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\transparent_object.shader]...
    2020-07-30 03:25:50,420 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [237]: Starting to slice...
    2020-07-30 03:25:50,420 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [255]: Going to slice build plate [0]!
    2020-07-30 03:25:50,426 - WARNING - [Thread-5] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x000002B77C41E510> is deprecated (since 4.4): Please use extruderList instead.
    2020-07-30 03:25:50,835 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [444]: Sending slice message took 0.414142370223999 seconds
    2020-07-30 03:25:52,711 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] [WARNING] Mesh has disconnected faces!
    2020-07-30 03:25:52,714 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] [WARNING] Mesh has overlapping faces!
    2020-07-30 03:25:53,662 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] [WARNING]  -s support_pattern="zigzag" -s travel_compensate_overlapping_walls_enabled="True" -s wireframe_printspeed_bottom="5" -s prime_tower_enable="False" -s retraction_hop_only_when_collides="False" -s flow_rate_max_extrusion_offset="0" -s speed_slowdown_layers="2" -s connect_infill_polygons="False" -s support_line_width="0.4" -s machine_name="Creality Ender-3" -s jerk_travel_layer_0="8" -s wireframe_straight_before_down="20" -s speed_wall_x="25.0" -s speed_equalize_flow_enabled="False" -s skirt_brim_speed="20.0" -s support_tree_collision_resolution="0.2" -s prime_tower_flow="100" -s machine_nozzle_cool_down_speed="2.0" -s acceleration_support="500" -s speed_travel="150.0" -s z_seam_y="235" -s machine_buildplate_type="glass" -s jerk_layer_0="8" -s wall_min_flow="0" -s material_guid="" -s machine_height="250" -s slicing_tolerance="middle" -s machine_heated_build_volume="False" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s meshfix_maximum_deviation="0.05" -s infill_wipe_dist="0.0" -s cool_min_layer_time_fan_speed_max="10" -s acceleration_wall_x="500" -s small_feature_speed_factor_0="50" -s retraction_min_travel="1.5" -s jerk_ironing="8" -s bridge_skin_density="100" -s draft_shield_height="10" -s cross_support_density_image="" -s switch_extruder_retraction_amount="16" -s mold_roof_height="0.5" -s acceleration_support_interface="500" -s material_crystallinity="False" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[[[-117.5, 117.5], [-117.5, 108], [117.5, 108], [117.5, 117.5]], [[-117.5, -108], [-117.5, -117.5], [117.5, -117.5], [117.5, -108]]]" -s line_width="0.4" -s machine_steps_per_mm_x="50" -s small_feature_speed_factor="50" -s machine_settings="0" -s ironing_pattern="zigzag" -s support_bottom_line_width="0.4" -s infill_material_flow="100" -s bridge_skin_material_flow_3="110" -s raft_surface_line_width="0.4" -s cross_infill_density_image="" -s support_roof_enable="True" -s jerk_support="8" -s raft_interface_thickness="0.30000000000000004" -s retraction_retract_speed="25" -s support_enable="False" -s spaghetti_infill_enabled="False" -s switch_extruder_extra_prime_amount="0" -s machine_steps_per_mm_z="50" -s small_hole_max_size="0" -s support_roof_height="0.8" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s raft_jerk="8" -s top_layers="4" -s brim_width="8.0" -s acceleration_travel="500" -s wall_line_width="0.4" -s travel_compensate_overlapping_walls_x_enabled="True" -s sub_div_rad_add="0.4" -s travel_avoid_other_parts="True" -s acceleration_travel_layer_0="500" -s machine_width="235" -s wireframe_enabled="False" -s material_diameter="1.75" -s support_offset="0" -s bridge_skin_support_threshold="50" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s bridge_fan_speed_2="0" -s support_tower_maximum_supported_diameter="3.0" -s filter_out_tiny_gaps="False" -s raft_interface_acceleration="500" -s cool_lift_head="False" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s draft_shield_height_limitation="full" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s prime_blob_enable="False" -s wall_overhang_angle="90" -s wireframe_fall_down="0.5" -s bottom_thickness="0.8" -s support_tower_roof_angle="65" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s blackmagic="0" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s acceleration_infill="500" -s material_flush_purge_speed="0.5" -s travel_speed="150.0" -s mold_angle="40" -s support_interface_height="0.8" -s jerk_wall_x="8" -s wireframe_roof_fall_down="2" -s raft_surface_speed="25.0" -s wall_line_count="2" -s raft_base_line_width="0.8" -s xy_offset="0" -s acceleration_support_roof="500" -s gradual_infill_steps="0" -s raft_base_jerk="8" -s center_object="False" -s machine_depth="235" -s alternate_carve_order="True" -s support_angle="45" -s machine_max_jerk_e="5" -s material_flow_layer_0="100" -s alternate_extra_perimeter="False" -s bridge_wall_min_length="5" -s ironing_enabled="False" -s support_interface_offset="0.0" -s default_material_bed_temperature="50" -s support_roof_density="33.333" -s material_standby_temperature="150" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s material_print_temp_prepend="True" -s machine_max_jerk_xy="10" -s wireframe_roof_outer_delay="0.2" -s material_adhesion_tendency="10" -s z_seam_x="117.5" -s jerk_topbottom="8" -s wipe_hop_speed="5" -s support_wall_count="1" -s wireframe_roof_drag_along="0.8" -s jerk_support_roof="8" -s top_thickness="0.8" -s infill_overlap_mm="0.12" -s support_extruder_nr="0" -s support_fan_enable="False" -s infill_sparse_thickness="0.2" -s layer_start_x="0.0" -s support_top_distance="0.2" -s smooth_spiralized_contours="True" -s support_brim_enable="True" -s support_extruder_nr_layer_0="0" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s wireframe_bottom_delay="0" -s material_anti_ooze_retraction_speed="5" -s material_end_of_filament_purge_speed="0.5" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s time="03:25:50" -s wall_0_extruder_nr="-1" -s initial_extruder_nr="0" -s jerk_travel="8" -s acceleration_support_infill="500" -s bridge_skin_density_3="80" -s wipe_retraction_extra_prime_amount="0" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s skirt_brim_line_width="0.4" -s machine_nozzle_head_distance="3" -s machine_show_variants="False" -s speed_support_bottom="25.0" -s mold_width="5" -s machine_endstop_positive_direction_z="True" -s minimum_roof_area="10" -s wireframe_nozzle_clearance="1" -s infill_overlap="30.0" -s bridge_skin_density_2="75" -s speed_ironing="16.666666666666668" -s material_no_load_move_factor="0.940860215" -s spaghetti_max_height="2.0" -s initial_layer_line_width_factor="100.0" -s wireframe_top_delay="0" -s day="Thu" -s roofing_pattern="lines" -s print_bed_temperature="50" -s speed_equalize_flow_max="150" -s support_infill_extruder_nr="0" -s ironing_flow="10.0" -s support_roof_extruder_nr="0" -s support_initial_layer_line_distance="2.0" -s support_conical_angle="30" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s acceleration_topbottom="500" -s skin_outline_count="1" -s magic_spiralize="False" -s support_bottom_stair_step_height="0.3" -s bridge_enable_more_layers="True" -s material_break_temperature="50" -s draft_shield_enabled="False" -s adaptive_layer_height_enabled="False" -s material_initial_print_temperature="210" -s prime_tower_min_volume="6" -s optimize_wall_printing_order="True" -s support_roof_line_width="0.4" -s machine_max_feedrate_z="10" -s min_skin_width_for_expansion="4.898587196589413e-17" -s machine_acceleration="500" -s speed_z_hop="5" -s raft_surface_jerk="8" -s support_infill_rate="20" -s acceleration_ironing="500" -s speed_infill="50.0" -s material_bed_temperature="50" -s wireframe_printspeed_down="5" -s support_type="everywhere" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s raft_interface_speed="18.75" -s wall_line_width_0="0.4" -s material_bed_temp_prepend="True" -s retraction_combing_max_distance="30" -s hole_xy_offset="0" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s cool_fan_speed_0="0" -s wireframe_printspeed_flat="5" -s jerk_print="8" -s acceleration_support_bottom="500" -s command_line_settings="0" -s bridge_fan_speed="100" -s ooze_shield_enabled="False" -s machine_center_is_zero="False" -s material_surface_energy="100" -s raft_base_speed="18.75" -s resolution="0" -s prime_tower_position_y="203.6" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s support_interface_density="33.333" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2020-07-30 03:25:53,664 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G92 E0 ; Reset Extruder
    2020-07-30 03:25:53,666 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G28 ; Home all axes
    2020-07-30 03:25:53,668 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2020-07-30 03:25:53,670 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2020-07-30 03:25:53,672 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2020-07-30 03:25:53,674 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2020-07-30 03:25:53,676 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2020-07-30 03:25:53,678 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G92 E0 ; Reset Extruder
    2020-07-30 03:25:53,680 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2020-07-30 03:25:53,682 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_max_acceleration_e="5000" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s wipe_retraction_speed="25" -s extruder_prime_pos_x="0" -s meshfix_union_all="True" -s machine_extruder_count="1" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s flow_rate_extrusion_offset_factor="100" -s adaptive_layer_height_variation="0.04" -s minimum_polygon_circumference="1.0" -s skin_no_small_gaps_heuristic="False" -s speed_support_infill="25.0" -s support_skip_zag_per_mm="20" -s infill_offset_y="0" -s support_join_distance="2.0" -s spaghetti_inset="0.2" -s magic_fuzzy_skin_point_dist="0.8" -s wipe_retraction_enable="True" -s machine_min_cool_heat_time_window="50.0" -s cool_min_speed="10" -s infill_mesh_order="0" -s infill_support_angle="40" -s machine_firmware_retract="False" -s raft_surface_thickness="0.2" -s prime_tower_position_x="223.6" -s support_bottom_distance="0.2" -s acceleration_wall="500" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s wireframe_drag_along="0.6" -s wireframe_strategy="compensate" -s speed_topbottom="25.0" -s raft_margin="15" -s infill_mesh="False" -s infill_line_distance="6.0" -s support_roof_material_flow="100" -s spaghetti_infill_stepped="True" -s bridge_skin_speed_2="12.5" -s acceleration_wall_0="500" -s switch_extruder_prime_speed="20" -s material_flush_purge_length="60" -s wireframe_flow_connection="100" -s top_bottom_thickness="0.8" -s wireframe_top_jump="0.6" -s support_tower_diameter="3.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s wipe_pause="0" -s adaptive_layer_height_variation_step="0.04" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s speed_wall_0="25.0" -s meshfix="0" -s skirt_brim_minimal_length="250" -s support_xy_overrides_z="xy_overrides_z" -s support_bottom_offset="0.0" -s speed_wall="25.0" -s coasting_speed="90" -s roofing_layer_count="0" -s material_bed_temperature_layer_0="50" -s retraction_count_max="100" -s extruder_prime_pos_abs="False" -s ooze_shield_angle="60" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s support_zag_skip_count="10" -s skirt_gap="10.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s machine_steps_per_mm_e="1600" -s retraction_combing="noskin" -s skirt_brim_material_flow="100" -s machine_extruders_share_heater="False" -s cooling="0" -s wall_thickness="0.8" -s support_bottom_height="0.8" -s material_print_temp_wait="True" -s acceleration_enabled="False" -s retraction_prime_speed="25" -s z_seam_type="back" -s speed_print_layer_0="20.0" -s support_line_distance="2.0" -s machine_shape="rectangular" -s prime_tower_size="20" -s speed_support_interface="25.0" -s wall_0_inset="0" -s speed="0" -s z_seam_position="back" -s material_shrinkage_percentage="0" -s skin_line_width="0.4" -s wipe_move_distance="20" -s infill_pattern="cubic" -s minimum_interface_area="10" -s infill_before_walls="False" -s zig_zaggify_infill="False" -s travel_avoid_supports="True" -s shell="0" -s spaghetti_infill_extra_volume="0" -s support_interface_extruder_nr="0" -s spaghetti_max_infill_angle="10" -s infill_line_width="0.4" -s roofing_material_flow="100" -s wireframe_up_half_speed="0.3" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s infill_extruder_nr="-1" -s acceleration_skirt_brim="500" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s clean_between_layers="False" -s cool_min_layer_time="10" -s machine_max_feedrate_x="500" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s material_extrusion_cool_down_speed="0.7" -s top_bottom_pattern="lines" -s material_maximum_park_duration="300" -s infill_support_enabled="False" -s travel="0" -s max_extrusion_before_wipe="10" -s ooze_shield_dist="2" -s wireframe_height="3" -s support_interface_enable="True" -s support_brim_width="4" -s jerk_support_bottom="8" -s conical_overhang_enabled="False" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s machine_end_gcode="G91 ;Relative positioning
    2020-07-30 03:25:53,684 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 E-2 F2700 ;Retract a bit
    2020-07-30 03:25:53,686 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2020-07-30 03:25:53,688 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2020-07-30 03:25:53,690 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 Z10 ;Raise Z more
    2020-07-30 03:25:53,692 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G90 ;Absolute positionning
    2020-07-30 03:25:53,694 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:25:53,696 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0 Y235 ;Present print
    2020-07-30 03:25:53,698 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M106 S0 ;Turn-off fan
    2020-07-30 03:25:53,700 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M104 S0 ;Turn-off hotend
    2020-07-30 03:25:53,702 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M140 S0 ;Turn-off bed
    2020-07-30 03:25:53,704 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:25:53,706 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M84 X Y E ;Disable all steppers but Z
    2020-07-30 03:25:53,709 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] " -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s fill_perimeter_gaps="everywhere" -s carve_multiple_volumes="False" -s retraction_amount="6.5" -s skin_preshrink="0.8" -s ironing_inset="0.2" -s spaghetti_flow="20" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s material_flow_dependent_temperature="False" -s support_material_flow="100" -s wipe_retraction_prime_speed="25" -s support_bottom_enable="True" -s retraction_enable="True" -s infill_sparse_density="20" -s minimum_support_area="2" -s jerk_skirt_brim="8" -s roofing_extruder_nr="-1" -s cool_fan_speed_max="100.0" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s wall_material_flow="100" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s remove_empty_first_layers="True" -s bottom_layers="4" -s prime_tower_brim_enable="False" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s outer_inset_first="False" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s support_conical_enabled="False" -s cool_fan_speed_min="100.0" -s support_tree_branch_distance="1" -s jerk_infill="8" -s wall_min_flow_retract="False" -s machine_nozzle_size="0.4" -s support_tree_branch_diameter_angle="5" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.05" -s speed_roofing="25.0" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s support_roof_line_distance="2.4000240002400024" -s brim_outside_only="True" -s min_infill_area="0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s draft_shield_dist="10" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s support_roof_offset="0.0" -s retraction_extra_prime_amount="0" -s acceleration_print="500" -s machine_max_acceleration_z="100" -s fill_outline_gaps="False" -s raft_interface_fan_speed="0" -s coasting_volume="0.064" -s wall_x_extruder_nr="-1" -s experimental="0" -s gantry_height="25" -s support_interface_skip_height="0.2" -s material="0" -s expand_skins_expand_distance="0.8" -s support_supported_skin_fan_speed="100" -s wireframe_printspeed_up="5" -s wipe_hop_amount="0.2" -s extruder_prime_pos_y="0" -s extruders_enabled_count="1" -s mesh_position_y="0" -s support_tree_angle="40" -s material_final_print_temperature="210" -s machine_max_acceleration_y="500" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s bridge_wall_material_flow="50" -s material_print_temperature="210" -s conical_overhang_angle="50" -s speed_support_roof="25.0" -s machine_nozzle_tip_outer_diameter="1" -s max_skin_angle_for_expansion="90" -s wipe_retraction_amount="6.5" -s default_material_print_temperature="210" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s brim_gap="0" -s cutting_mesh="False" -s wireframe_printspeed="5" -s platform_adhesion="0" -s wall_line_width_x="0.4" -s magic_fuzzy_skin_thickness="0.3" -s magic_fuzzy_skin_enabled="False" -s wireframe_flat_delay="0.1" -s gradual_support_infill_steps="0" -s layer_0_z_overlap="0.15" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s speed_layer_0="20.0" -s support_mesh_drop_down="True" -s machine_max_feedrate_y="500" -s build_volume_temperature="28" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s wipe_retraction_retract_speed="25" -s z_seam_relative="False" -s layer_height_0="0.2" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s top_skin_preshrink="0.8" -s support_interface_material_flow="100" -s cool_fan_speed="100.0" -s machine_steps_per_mm_y="50" -s machine_minimum_feedrate="0.0" -s support_bottom_line_distance="2.4000240002400024" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s raft_smoothing="5" -s material_break_speed="25" -s material_break_preparation_retracted_position="-16" -s support="0" -s skin_edge_support_layers="0" -s raft_interface_jerk="8" -s infill_wall_line_count="0" -s relative_extrusion="False" -s adhesion_extruder_nr="0" -s raft_base_line_spacing="1.6" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s bottom_skin_preshrink="0.8" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s travel_compensate_overlapping_walls_0_enabled="False" -s support_mesh="False" -s gradual_support_infill_step_height="1" -s skin_angles="[ ]" -s jerk_prime_tower="8" -s adaptive_layer_height_threshold="0.2" -s raft_speed="25.0" -s support_roof_pattern="grid" -s magic_fuzzy_skin_outside_only="False" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_bottom_stair_step_width="5.0" -s material_flow="100" -s retraction_extrusion_window="10" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s material_bed_temp_wait="True" -s support_bottom_angles="[ ]" -s infill="0" -s raft_interface_line_spacing="1.0" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s wipe_brush_pos_x="100" -s jerk_roofing="8" -s wireframe_flow="100" -s material_break_preparation_speed="2" -s speed_print="50.0" -s brim_replaces_support="False" -s meshfix_maximum_travel_resolution="0.05" -s retraction_speed="25" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s prime_tower_line_width="0.4" -s infill_multiplier="1" -s raft_surface_layers="2" -s machine_max_acceleration_x="500" -s infill_offset_x="0" -s jerk_wall="8" -s raft_surface_fan_speed="0" -s mold_enabled="False" -s date="30-07-2020" -s machine_heat_zone_length="16" -s support_tree_enable="False" -s skin_overlap_mm="0.04" -s support_use_towers="False" -s jerk_support_infill="8" -s small_feature_max_length="0.0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s brim_line_count="20" -s skin_edge_support_thickness="0" -s support_brim_line_count="10" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s retract_at_layer_change="False" -s skin_material_flow="100" -s wireframe_roof_inset="3" -s support_xy_distance_overhang="0.4" -s print_sequence="all_at_once" -s bridge_skin_speed_3="12.5" -s jerk_wall_0="8" -s machine_endstop_positive_direction_x="False" -s machine_use_extruder_offset_to_offset_coords="True" -s retraction_hop="0.2" -s dual="0" -s jerk_enabled="False" -s layer_height="0.2" -s bridge_sparse_infill_max_density="0" -s print_temperature="210" -e0 -s support_pattern="zigzag" -s travel_compensate_overlapping_walls_enabled="True" -s speed_travel_layer_0="100.0" -s retraction_hop_only_when_collides="False" -s raft_interface_fan_speed="0" -s acceleration_travel_layer_0="500" -s connect_infill_polygons="False" -s support_line_width="0.4" -s bridge_fan_speed="100" -s jerk_travel_layer_0="8" -s speed_wall_x="25.0" -s speed_equalize_flow_enabled="False" -s extruder_prime_pos_z="0" -s machine_extruder_start_pos_x="0" -s skirt_brim_speed="20.0" -s alternate_extra_perimeter="False" -s support_tree_collision_resolution="0.2" -s prime_tower_flow="100" -s machine_nozzle_cool_down_speed="2.0" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s acceleration_support="500" -s speed_travel="150.0" -s speed_equalize_flow_max="150" -s machine_extruder_start_code="" -s z_seam_y="235" -s jerk_layer_0="8" -s wall_min_flow="0" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s slicing_tolerance="middle" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s meshfix_maximum_deviation="0.05" -s infill_wipe_dist="0.0" -s raft_base_fan_speed="0" -s switch_extruder_retraction_speeds="20" -s cool_min_layer_time_fan_speed_max="10" -s acceleration_wall_x="500" -s small_feature_speed_factor_0="50" -s retraction_min_travel="1.5" -s jerk_ironing="8" -s bridge_sparse_infill_max_density="0" -s bridge_skin_density="100" -s cross_support_density_image="" -s switch_extruder_retraction_amount="16" -s mold_roof_height="0.5" -s acceleration_support_interface="500" -s material_crystallinity="False" -s line_width="0.4" -s machine_steps_per_mm_x="50" -s small_feature_speed_factor="50" -s machine_settings="0" -s ironing_pattern="zigzag" -s acceleration_print="500" -s support_bottom_line_width="0.4" -s infill_material_flow="100" -s bridge_skin_material_flow_3="110" -s raft_surface_line_width="0.4" -s cross_infill_density_image="" -s support_roof_enable="True" -s jerk_support="8" -s raft_interface_thickness="0.30000000000000004" -s retraction_retract_speed="45" -s spaghetti_infill_enabled="False" -s switch_extruder_extra_prime_amount="0" -s machine_steps_per_mm_z="50" -s small_hole_max_size="0" -s support_roof_height="0.8" -s support_bottom_height="0.8" -s material_flush_purge_speed="0.5" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s resolution="0" -s extruder_nr="0" -s raft_jerk="8" -s top_layers="4" -s brim_width="8.0" -s machine_extruder_end_pos_x="0" -s acceleration_travel="500" -s wall_line_width="0.4" -s travel_compensate_overlapping_walls_x_enabled="True" -s sub_div_rad_add="0.4" -s travel_avoid_other_parts="True" -s material_diameter="1.75" -s support_offset="0" -s bridge_skin_support_threshold="50" -s extruder_prime_pos_y="0" -s material_break_retracted_position="-50" -s raft_surface_line_spacing="0.4" -s bridge_fan_speed_2="0" -s support_tower_maximum_supported_diameter="3.0" -s support_xy_distance_overhang="0.4" -s filter_out_tiny_gaps="False" -s raft_interface_acceleration="500" -s cool_lift_head="False" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s gradual_support_infill_steps="0" -s brim_gap="0" -s blackmagic="0" -s wipe_retraction_amount="5" -s bridge_wall_material_flow="50" -s support_tree_angle="40" -s material_final_print_temperature="200" -s mesh_position_y="0" -s support_conical_enabled="False" -s cool_fan_speed_min="100" -s support_tree_branch_distance="1" -s support_roof_density="33.333" -s material_standby_temperature="180" -s material_flow_layer_0="100" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s skin_no_small_gaps_heuristic="False" -s experimental="0" -s travel_compensate_overlapping_walls_0_enabled="False" -s fill_outline_gaps="False" -s retraction_extra_prime_amount="0" -s support_roof_offset="0.0" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s acceleration_support_infill="500" -s bridge_skin_density_3="80" -s wipe_retraction_extra_prime_amount="0" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s raft_surface_thickness="0.2" -s cool_fan_speed_0="0" -s skirt_brim_line_width="0.4" -s machine_nozzle_head_distance="3" -s speed_support_bottom="25.0" -s skirt_brim_minimal_length="250" -s support_xy_overrides_z="xy_overrides_z" -s mold_width="5" -s machine_endstop_positive_direction_z="True" -s minimum_roof_area="10" -s infill_overlap="30.0" -s bridge_skin_density_2="75" -s top_bottom_thickness="0.8" -s speed_ironing="16.666666666666668" -s material_no_load_move_factor="0.940860215" -s spaghetti_max_height="2.0" -s initial_layer_line_width_factor="100.0" -s raft_margin="15" -s acceleration_wall="500" -s support_bottom_distance="0.2" -s roofing_pattern="lines" -s material_extrusion_cool_down_speed="0.7" -s ironing_flow="10.0" -s support_initial_layer_line_distance="2.0" -s min_skin_width_for_expansion="4.898587196589413e-17" -s support_conical_angle="30" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s acceleration_topbottom="500" -s skin_outline_count="1" -s wall_line_count="2" -s support_bottom_stair_step_height="0.3" -s bridge_enable_more_layers="True" -s material_break_temperature="50" -s material_initial_print_temperature="200" -s prime_tower_min_volume="6" -s magic_fuzzy_skin_enabled="False" -s z_seam_x="117.5" -s optimize_wall_printing_order="True" -s support_roof_line_width="0.4" -s support_skip_zag_per_mm="20" -s speed_support_infill="25.0" -s bottom_layers="4" -s meshfix="0" -s speed_wall_0="25.0" -s speed_z_hop="5" -s raft_surface_jerk="8" -s support_infill_rate="20" -s acceleration_ironing="500" -s speed_infill="50.0" -s raft_interface_speed="18.75" -s wall_line_width_0="0.4" -s retraction_combing_max_distance="30" -s hole_xy_offset="0" -s machine_steps_per_mm_e="1600" -s switch_extruder_prime_speed="20" -s acceleration_wall_0="500" -s machine_extruder_end_pos_abs="False" -s jerk_infill="8" -s wall_min_flow_retract="False" -s mold_angle="40" -s magic_fuzzy_skin_thickness="0.3" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s infill_line_distance="6.0" -s support_roof_material_flow="100" -s spaghetti_infill_stepped="True" -s bridge_skin_speed_2="12.5" -s spaghetti_infill_extra_volume="0" -s spaghetti_max_infill_angle="10" -s infill_line_width="0.4" -s travel_avoid_supports="True" -s shell="0" -s roofing_material_flow="100" -s mesh_position_x="0" -s ironing_only_highest_layer="False" -s platform_adhesion="0" -s wall_line_width_x="0.4" -s support_tree_branch_diameter_angle="5" -s support_interface_offset="0.0" -s spaghetti_inset="0.2" -s infill_support_enabled="False" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s support_tower_diameter="3.0" -s retraction_hop_enabled="False" -s acceleration_roofing="500" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s wipe_pause="0" -s retraction_count_max="100" -s skin_material_flow="100" -s cool_fan_full_at_height="0.6000000000000001" -s initial_bottom_layers="4" -s extruder_prime_pos_abs="False" -s support_bottom_offset="0.0" -s acceleration_skirt_brim="500" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s clean_between_layers="False" -s cool_min_layer_time="10" -s wipe_repeat_count="5" -s support_skip_some_zags="False" -s bridge_fan_speed_3="0" -s material_print_temperature="200" -s speed_support_roof="25.0" -s conical_overhang_angle="50" -s roofing_angles="[ ]" -s support_tree_branch_diameter="2" -s z_seam_corner="z_seam_corner_weighted" -s jerk_print_layer_0="8" -s support_bottom_material_flow="100" -s speed="0" -s z_seam_position="back" -s default_material_print_temperature="200" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_adhesion_tendency="0" -s speed_topbottom="25.0" -s wall_thickness="0.8" -s spaghetti_flow="20" -s prime_tower_wipe_enabled="True" -s layer_start_y="0.0" -s material_flow_dependent_temperature="False" -s support_material_flow="100" -s wipe_retraction_prime_speed="45" -s material_shrinkage_percentage="0" -s skin_line_width="0.4" -s wipe_move_distance="20" -s infill_pattern="cubic" -s minimum_interface_area="10" -s infill_before_walls="False" -s zig_zaggify_infill="False" -s retraction_prime_speed="45" -s z_seam_type="back" -s machine_extruder_start_pos_y="0" -s bridge_skin_speed_3="12.5" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s skin_preshrink="0.8" -s ironing_inset="0.2" -s fill_perimeter_gaps="everywhere" -s retraction_amount="5" -s cooling="0" -s travel="0" -s max_extrusion_before_wipe="10" -s speed_wall="25.0" -s coasting_speed="90" -s bottom_thickness="0.8" -s roofing_layer_count="0" -s machine_extruder_cooling_fan_number="0" -s jerk_travel="8" -s coasting_volume="0.064" -s wipe_hop_speed="5" -s support_bottom_enable="True" -s retraction_enable="True" -s infill_sparse_density="20" -s minimum_support_area="2" -s coasting_min_volume="0.8" -s magic_mesh_surface_mode="normal" -s jerk_skirt_brim="8" -s cool_fan_speed_max="100" -s support_interface_angles="[ ]" -s wall_material_flow="100" -s support_interface_pattern="grid" -s raft_fan_speed="0" -s acceleration_infill="500" -s outer_inset_first="False" -s machine_nozzle_size="0.4" -s top_bottom_pattern_0="lines" -s infill_angles="[ ]" -s speed_roofing="25.0" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s support_roof_line_distance="2.4000240002400024" -s brim_outside_only="True" -s infill_offset_y="0" -s support_join_distance="2.0" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s jerk_support_roof="8" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s speed_print_layer_0="20.0" -s support_line_distance="2.0" -s wall_overhang_angle="90" -s support_interface_skip_height="0.2" -s material_surface_energy="100" -s raft_base_speed="18.75" -s cool_fan_speed="100" -s machine_steps_per_mm_y="50" -s speed_layer_0="20.0" -s top_skin_expand_distance="0.8" -s infill_randomize_start_location="False" -s layer_0_z_overlap="0.15" -s wipe_retraction_speed="45" -s meshfix_union_all="True" -s extruder_prime_pos_x="0" -s cool_fan_enabled="True" -s support_xy_distance="0.8" -s min_infill_area="0" -s support_brim_enable="True" -s layer_start_x="0.0" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s ironing_line_spacing="0.1" -s retraction_hop_after_extruder_switch_height="0.2" -s jerk_support_bottom="8" -s conical_overhang_enabled="False" -s material="0" -s expand_skins_expand_distance="0.8" -s support_supported_skin_fan_speed="100" -s machine_nozzle_temp_enabled="True" -s skirt_line_count="3" -s wipe_retraction_retract_speed="45" -s z_seam_relative="False" -s support_roof_angles="[ ]" -s material_anti_ooze_retracted_position="-4" -s top_skin_preshrink="0.8" -s support_interface_material_flow="100" -s support_bottom_line_distance="2.4000240002400024" -s multiple_mesh_overlap="0.15" -s acceleration_prime_tower="500" -s raft_smoothing="5" -s material_break_speed="25" -s material_break_preparation_retracted_position="-16" -s support="0" -s skin_edge_support_layers="0" -s raft_interface_jerk="8" -s infill_wall_line_count="0" -s raft_base_line_spacing="1.6" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s bottom_skin_preshrink="0.8" -s machine_nozzle_id="unknown" -s support_bottom_pattern="grid" -s wall_0_wipe_dist="0.0" -s gradual_support_infill_step_height="1" -s skin_angles="[ ]" -s machine_extruder_end_pos_y="0" -s jerk_prime_tower="8" -s raft_speed="25.0" -s support_roof_pattern="grid" -s machine_extruder_end_code="" -s machine_extruder_start_pos_abs="False" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s meshfix_maximum_resolution="0.05" -s skirt_brim_material_flow="100" -s support_bottom_angles="[ ]" -s raft_base_line_width="0.8" -s infill="0" -s raft_interface_line_spacing="1.0" -s wipe_brush_pos_x="100" -s raft_surface_acceleration="500" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s material_break_preparation_speed="2" -s skin_overlap="10.0" -s acceleration_layer_0="500" -s speed_print="50.0" -s brim_replaces_support="False" -s meshfix_maximum_travel_resolution="0.05" -s retraction_speed="45" -s prime_tower_line_width="0.4" -s xy_offset="0" -s support_zag_skip_count="10" -s skirt_gap="10.0" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s ironing_enabled="False" -s infill_multiplier="1" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s machine_nozzle_offset_x="0" -s raft_acceleration="500" -s support_interface_density="33.333" -s support_conical_min_width="5.0" -s gradual_infill_step_height="1.5" -s raft_surface_layers="2" -s infill_offset_x="0" -s jerk_wall="8" -s raft_surface_fan_speed="0" -s mold_enabled="False" -s machine_heat_zone_length="16" -s skin_overlap_mm="0.04" -s support_use_towers="False" -s jerk_support_infill="8" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s small_feature_max_length="0.0" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s brim_line_count="20" -s skin_edge_support_thickness="0" -s wipe_hop_amount="0.2" -s support_brim_line_count="10" -s retract_at_layer_change="False" -s jerk_wall_0="8" -s support_interface_height="0.8" -s retraction_hop="0.2" -s dual="0" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s support_brim_width="4" -s support_interface_enable="True" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s infill_support_angle="40" -s machine_endstop_positive_direction_x="False" -s material_end_of_filament_purge_speed="0.5" -s machine_nozzle_offset_y="0" -s material_flush_purge_length="60" -s raft_base_jerk="8" -s material_anti_ooze_retraction_speed="5" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s roofing_line_width="0.4" -s support_top_distance="0.2" -s infill_overlap_mm="0.12" -s top_thickness="0.8" -s magic_fuzzy_skin_outside_only="False" -s support_wall_count="1" -s jerk_topbottom="8" -s wall_0_inset="0" -s speed_support_interface="25.0" -s jerk_print="8" -s command_line_settings="0" -s acceleration_support_bottom="500" -s support_angle="45" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s center_object="False" -s gradual_infill_steps="0" -s acceleration_support_roof="500" -s retraction_extrusion_window="10" -s material_flow="100" -s raft_surface_speed="25.0" -s jerk_wall_x="8" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s bridge_wall_speed="12.5" -s support_tower_roof_angle="65" -s prime_blob_enable="False" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -g -e0 -l "0" -s extruder_nr="0"
    2020-07-30 03:25:55,350 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [844]: Backend quit with return code 3221225477. Resetting process and socket.
    2020-07-30 03:25:55,572 - INFO - [MainThread] UM.Backend.Backend._onSocketError [214]: Backend crashed or closed.
    2020-07-30 03:25:55,574 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first.
    2020-07-30 03:25:55,575 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Attempting to kill the engine process
    2020-07-30 03:25:55,578 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first.
    2020-07-30 03:25:55,582 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [184]: Socket state changed to Listening
    2020-07-30 03:25:55,587 - INFO - [MainThread] UM.Backend.Backend.startEngine [86]: Started engine process: C:\Program Files\Ultimaker Cura 4.6\CuraEngine.exe
    2020-07-30 03:25:55,590 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [106]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.6\\CuraEngine.exe', 'connect', '127.0.0.1:49675', '']
    2020-07-30 03:25:55,623 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:25:55,626 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Connected
    2020-07-30 03:25:55,628 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [177]: Backend connected on port 49675
    2020-07-30 03:25:55,631 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] Cura_SteamEngine version 4.6.2
    2020-07-30 03:25:55,634 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] Copyright (C) 2019 Ultimaker
    2020-07-30 03:25:55,636 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:25:55,638 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] This program is free software: you can redistribute it and/or modify
    2020-07-30 03:25:55,641 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2020-07-30 03:25:55,643 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2020-07-30 03:25:55,646 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] (at your option) any later version.
    2020-07-30 03:25:55,648 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:25:55,650 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] This program is distributed in the hope that it will be useful,
    2020-07-30 03:25:55,653 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2020-07-30 03:25:55,655 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2020-07-30 03:25:55,657 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] GNU Affero General Public License for more details.
    2020-07-30 03:25:55,660 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:25:55,662 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] You should have received a copy of the GNU Affero General Public License
    2020-07-30 03:25:55,664 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    2020-07-30 03:25:58,415 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
    2020-07-30 03:26:49,273 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2020-07-30 03:26:49,277 - INFO - [MainThread] cura.CuraApplication.closeApplication [577]: Close application
    2020-07-30 03:26:49,286 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [470]: Shutting down cura
    2020-07-30 03:26:49,324 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Attempting to kill the engine process
    2020-07-30 03:26:49,324 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [310]: Killing engine process
    2020-07-30 03:26:49,325 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [313]: Engine process is killed. Received return code 1
    2020-07-30 03:28:27,240 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
    2020-07-30 03:28:27,256 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
    2020-07-30 03:28:27,271 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
    2020-07-30 03:28:27,271 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
    2020-07-30 03:28:27,287 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
    2020-07-30 03:28:27,287 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
    2020-07-30 03:28:27,303 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
    2020-07-30 03:28:27,303 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
    2020-07-30 03:28:27,318 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
    2020-07-30 03:28:27,334 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
    2020-07-30 03:28:27,334 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
    2020-07-30 03:28:27,350 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
    2020-07-30 03:28:27,350 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
    2020-07-30 03:28:27,367 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
    2020-07-30 03:28:27,367 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
    2020-07-30 03:28:27,383 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
    2020-07-30 03:28:27,383 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
    2020-07-30 03:28:27,383 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
    2020-07-30 03:28:27,399 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
    2020-07-30 03:28:27,414 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
    2020-07-30 03:28:27,414 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
    2020-07-30 03:28:27,430 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
    2020-07-30 03:28:27,445 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
    2020-07-30 03:28:27,445 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
    2020-07-30 03:28:27,464 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
    2020-07-30 03:28:27,493 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:28:27,494 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:28:27,495 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:28:27,497 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:28:27,499 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:28:27,501 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:28:27,503 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:28:27,504 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:28:27,510 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
    2020-07-30 03:28:27,513 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
    2020-07-30 03:28:27,528 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
    2020-07-30 03:28:27,528 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
    2020-07-30 03:28:27,544 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
    2020-07-30 03:28:27,544 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
    2020-07-30 03:28:27,559 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
    2020-07-30 03:28:27,559 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
    2020-07-30 03:28:27,575 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
    2020-07-30 03:28:27,591 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
    2020-07-30 03:28:27,591 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
    2020-07-30 03:28:27,703 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
    2020-07-30 03:28:27,703 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
    2020-07-30 03:28:27,703 - INFO - [Thread-1] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
    2020-07-30 03:28:27,977 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
    2020-07-30 03:28:28,130 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
    2020-07-30 03:28:28,192 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
    2020-07-30 03:28:28,241 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
    2020-07-30 03:28:28,288 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
    2020-07-30 03:28:28,351 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
    2020-07-30 03:28:28,398 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
    2020-07-30 03:28:28,475 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
    2020-07-30 03:28:28,504 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
    2020-07-30 03:28:28,551 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
    2020-07-30 03:28:28,614 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
    2020-07-30 03:28:28,665 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
    2020-07-30 03:28:28,711 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
    2020-07-30 03:28:28,727 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
    2020-07-30 03:28:28,727 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
    2020-07-30 03:28:28,743 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
    2020-07-30 03:28:28,758 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
    2020-07-30 03:28:28,758 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
    2020-07-30 03:28:28,774 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
    2020-07-30 03:28:28,790 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
    2020-07-30 03:28:28,790 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
    2020-07-30 03:28:28,805 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
    2020-07-30 03:28:28,805 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [374]: Loading all plugins took 2.096127510070801 seconds
    2020-07-30 03:28:28,821 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [160]: Looking for old configuration files to upgrade.
    2020-07-30 03:28:28,836 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,852 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:28:28,852 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,868 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,868 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:28:28,883 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,883 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:28:28,899 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:28:28,899 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,915 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,915 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:28:28,930 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:28:28,930 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:28:31,469 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [360]: Loading metadata into container registry took 2.429734945297241 seconds
    2020-07-30 03:28:31,594 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [111]: Select build plate: 0
    2020-07-30 03:28:31,594 - INFO - [MainThread] cura.CuraApplication.run [751]: Initializing machine error checker
    2020-07-30 03:28:31,910 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_ender3]
    2020-07-30 03:28:32,229 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [184]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3] at position [0]
    2020-07-30 03:28:32,229 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [156]: Extruder [creality_base_extruder_0 #2] has already been registered on machine [Creality Ender-3], not doing anything
    2020-07-30 03:28:32,229 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [74]: No machine with name Creality Ender-3 in list of firmware to check.
    2020-07-30 03:28:32,652 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [106]: Adding container tree for creality_ender3 took 0.4233269691467285 seconds.
    2020-07-30 03:28:32,652 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: BQ_PauseAtHeight
    2020-07-30 03:28:32,652 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ChangeAtZ
    2020-07-30 03:28:32,652 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ColorMix
    2020-07-30 03:28:32,652 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayRemainingTimeOnLCD
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: FilamentChange
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: InsertAtLayerChange
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeight
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightforRepetier
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: RetractContinue
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: SearchAndReplace
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: Stretch
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: TimeLapse
    2020-07-30 03:28:32,668 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: UsePreviousProbeMeasurements
    2020-07-30 03:28:32,746 - INFO - [MainThread] cura.CuraApplication.run [756]: Initializing machine manager
    2020-07-30 03:28:32,746 - INFO - [MainThread] cura.CuraApplication.run [761]: Initializing container manager
    2020-07-30 03:28:32,746 - INFO - [Thread-2] STLReader.STLReader.load_file [52]: Using NumPy-STL to load STL data.
    2020-07-30 03:28:32,761 - DEBUG - [Thread-2] UM.Mesh.MeshData.calculateNormalsFromVertices [548]: Calculating normals took 0.0 seconds
    2020-07-30 03:28:32,761 - DEBUG - [Thread-2] STLReader.STLReader._read [104]: Loaded a mesh with 8520 vertices
    2020-07-30 03:28:32,824 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2020-07-30 03:28:32,840 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light\theme.json
    2020-07-30 03:28:33,068 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [231]: Loaded theme C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light
    2020-07-30 03:28:33,443 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [135]: New error check scheduled.
    2020-07-30 03:28:33,913 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [311]: Creating post processing plugin view.
    2020-07-30 03:28:34,038 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [321]: Post processing view created.
    2020-07-30 03:28:34,134 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:28:35,216 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:28:35,216 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x0000020BAB8DE510> is deprecated (since 4.4): Please use extruderList instead.
    2020-07-30 03:28:35,325 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/PrintSetupSelector/Custom/CustomPrintSetup.qml:76:29: Unable to assign null to double
    2020-07-30 03:28:35,341 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2020-07-30 03:28:35,403 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:28:35,435 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
    2020-07-30 03:28:35,466 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2020-07-30 03:28:35,466 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [111]: Creating model checker view.
    2020-07-30 03:28:35,482 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [120]: Model checker view created.
    2020-07-30 03:28:35,482 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [71]: Creating dialog [MoreInfoWindow.qml]
    2020-07-30 03:28:35,497 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [542]: Requesting [updates] metadata from server.
    2020-07-30 03:28:35,497 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [112]: No auth data to retrieve the access_token from
    2020-07-30 03:28:35,513 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
    2020-07-30 03:28:35,513 - DEBUG - [MainThread] cura.CuraApplication.run [799]: Booting Cura took 9.29615831375122 seconds
    2020-07-30 03:28:35,513 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._processRequest [346]: Request [cec5b5724b7941d39fa60aade141703d] started
    2020-07-30 03:28:35,528 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:28:35,544 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:28:35,544 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:28:35,991 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:28:35,995 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:28:36,261 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [207]: Support for Vertex Array Objects: True
    2020-07-30 03:28:36,269 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2020-07-30 03:28:36,271 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 26.20.100.7324
    2020-07-30 03:28:36,274 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2020-07-30 03:28:36,277 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) UHD Graphics 630
    2020-07-30 03:28:36,279 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2020-07-30 03:28:36,282 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:28:36,295 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\selection.shader]...
    2020-07-30 03:28:36,305 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\select_face.shader]...
    2020-07-30 03:28:36,316 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:28:36,327 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\composite.shader]...
    2020-07-30 03:28:36,344 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\overhang.shader]...
    2020-07-30 03:28:36,362 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\striped.shader]...
    2020-07-30 03:28:36,378 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\transparent_object.shader]...
    2020-07-30 03:28:36,390 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\striped.shader]...
    2020-07-30 03:28:36,406 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray.shader]...
    2020-07-30 03:28:36,415 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray_composite.shader]...
    2020-07-30 03:28:36,433 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:28:36,443 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\grid.shader]...
    2020-07-30 03:28:36,455 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\platform.shader]...
    2020-07-30 03:28:36,488 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray.shader]...
    2020-07-30 03:28:37,021 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestFinished [408]: Request [cec5b5724b7941d39fa60aade141703d] finished.
    2020-07-30 03:28:37,024 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:28:37,144 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [187]: Error check finished, result = False, time = 3.7s
    2020-07-30 03:28:42,503 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [237]: Starting to slice...
    2020-07-30 03:28:42,503 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [255]: Going to slice build plate [0]!
    2020-07-30 03:28:42,504 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [263]: Build plate 0 has no objects to be sliced, skipping
    2020-07-30 03:28:43,008 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [237]: Starting to slice...
    2020-07-30 03:28:43,009 - WARNING - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [241]: Slice unnecessary, nothing has changed that needs reslicing.
    2020-07-30 03:28:52,509 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
    2020-07-30 03:28:54,559 - DEBUG - [MainThread] cura.TaskManagement.OnExitCallbackManager.triggerNextCallback [51]: No more on-app-exit callbacks to process. Tell the app to exit.
    2020-07-30 03:28:54,563 - INFO - [MainThread] cura.CuraApplication.closeApplication [577]: Close application
    2020-07-30 03:28:54,576 - DEBUG - [MainThread] UM.Qt.QtApplication.windowClosed [470]: Shutting down cura
    2020-07-30 03:28:54,609 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Attempting to kill the engine process
    2020-07-30 03:28:54,609 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [310]: Killing engine process
    2020-07-30 03:28:54,611 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [313]: Engine process is killed. Received return code 1
    2020-07-30 03:28:58,509 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FileLogger
    2020-07-30 03:28:58,520 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdateChecker
    2020-07-30 03:28:58,528 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin FirmwareUpdater
    2020-07-30 03:28:58,534 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzReader
    2020-07-30 03:28:58,541 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeGzWriter
    2020-07-30 03:28:58,549 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeProfileReader
    2020-07-30 03:28:58,564 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeReader
    2020-07-30 03:28:58,571 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin GCodeWriter
    2020-07-30 03:28:58,581 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ImageReader
    2020-07-30 03:28:58,589 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LegacyProfileReader
    2020-07-30 03:28:58,597 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalContainerProvider
    2020-07-30 03:28:58,606 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin LocalFileOutputDevice
    2020-07-30 03:28:58,614 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MachineSettingsAction
    2020-07-30 03:28:58,622 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ModelChecker
    2020-07-30 03:28:58,630 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MonitorStage
    2020-07-30 03:28:58,639 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PerObjectSettingsTool
    2020-07-30 03:28:58,647 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PostProcessingPlugin
    2020-07-30 03:28:58,654 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PrepareStage
    2020-07-30 03:28:58,660 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin PreviewStage
    2020-07-30 03:28:58,673 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RemovableDriveOutputDevice
    2020-07-30 03:28:58,679 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SentryLogger
    2020-07-30 03:28:58,695 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimulationView
    2020-07-30 03:28:58,703 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SliceInfoPlugin
    2020-07-30 03:28:58,714 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SolidView
    2020-07-30 03:28:58,722 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SupportEraser
    2020-07-30 03:28:58,745 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:28:58,745 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:28:58,755 - WARNING - [MainThread] UM.Logger.logException [110]: NoneType: None
    2020-07-30 03:28:58,755 - WARNING - [MainThread] UM.Logger.logException [106]: Exception: Failed to load packages for Marketplace
    2020-07-30 03:28:58,765 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin Toolbox
    2020-07-30 03:28:58,775 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin CameraTool
    2020-07-30 03:28:58,785 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin MirrorTool
    2020-07-30 03:28:58,802 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin RotateTool
    2020-07-30 03:28:58,817 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin ScaleTool
    2020-07-30 03:28:58,821 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SelectionTool
    2020-07-30 03:28:58,825 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TranslateTool
    2020-07-30 03:28:58,840 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin TrimeshReader
    2020-07-30 03:28:58,845 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPReader
    2020-07-30 03:28:58,855 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UFPWriter
    2020-07-30 03:28:58,865 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UltimakerMachineActions
    2020-07-30 03:28:58,965 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UM3NetworkPrinting
    2020-07-30 03:28:58,965 - INFO - [Thread-1] UpdateChecker.UpdateCheckerJob.run [40]: Checking for new version of cura
    2020-07-30 03:28:58,975 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin UpdateChecker
    2020-07-30 03:28:59,329 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin USBPrinting
    2020-07-30 03:28:59,534 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade21to22
    2020-07-30 03:28:59,600 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade22to24
    2020-07-30 03:28:59,666 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade25to26
    2020-07-30 03:28:59,727 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade26to27
    2020-07-30 03:28:59,790 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade27to30
    2020-07-30 03:28:59,854 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade30to31
    2020-07-30 03:28:59,920 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade32to33
    2020-07-30 03:28:59,970 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade33to34
    2020-07-30 03:28:59,985 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade34to35
    2020-07-30 03:28:59,994 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade35to40
    2020-07-30 03:29:00,003 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade40to41
    2020-07-30 03:29:00,013 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade41to42
    2020-07-30 03:29:00,022 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade42to43
    2020-07-30 03:29:00,030 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade43to44
    2020-07-30 03:29:00,039 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade44to45
    2020-07-30 03:29:00,048 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade45to46
    2020-07-30 03:29:00,056 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin VersionUpgrade460to462
    2020-07-30 03:29:00,063 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin SimpleView
    2020-07-30 03:29:00,077 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin X3DReader
    2020-07-30 03:29:00,099 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XmlMaterialProfile
    2020-07-30 03:29:00,107 - INFO - [MainThread] UM.Logger.info [122]: Loaded plugin XRayView
    2020-07-30 03:29:00,109 - DEBUG - [MainThread] UM.PluginRegistry.loadPlugins [374]: Loading all plugins took 2.1176958084106445 seconds
    2020-07-30 03:29:00,120 - INFO - [MainThread] UM.VersionUpgradeManager.upgrade [160]: Looking for old configuration files to upgrade.
    2020-07-30 03:29:00,145 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,149 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,152 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,155 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,158 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,160 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,162 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,165 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,165 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,171 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,174 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,177 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,181 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,183 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,186 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,188 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,191 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,195 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,198 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,200 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,203 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,205 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,205 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,211 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,214 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,217 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,223 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,228 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,234 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\packages.json, skip it
    2020-07-30 03:29:00,240 - WARNING - [MainThread] UM.VersionUpgradeManager._getUpgradeTasks [328]: Failed to get file version: .\plugins.json, skip it
    2020-07-30 03:29:00,771 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [237]: Starting to slice...
    2020-07-30 03:29:00,772 - WARNING - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [241]: Slice unnecessary, nothing has changed that needs reslicing.
    2020-07-30 03:29:02,916 - DEBUG - [MainThread] UM.Settings.ContainerRegistry.loadAllMetadata [360]: Loading metadata into container registry took 2.5581002235412598 seconds
    2020-07-30 03:29:03,100 - DEBUG - [MainThread] cura.Scene.CuraSceneController.setActiveBuildPlate [111]: Select build plate: 0
    2020-07-30 03:29:03,105 - INFO - [MainThread] cura.CuraApplication.run [751]: Initializing machine error checker
    2020-07-30 03:29:03,229 - INFO - [MainThread] cura.UI.MachineActionManager.addDefaultMachineActions [72]: Default machine actions added for machine definition [creality_ender3]
    2020-07-30 03:29:03,337 - INFO - [MainThread] cura.Settings.GlobalStack.addExtruder [184]: Extruder[creality_base_extruder_0 #2] added to [Creality Ender-3] at position [0]
    2020-07-30 03:29:03,340 - WARNING - [MainThread] cura.Settings.ExtruderManager.registerExtruder [156]: Extruder [creality_base_extruder_0 #2] has already been registered on machine [Creality Ender-3], not doing anything
    2020-07-30 03:29:03,340 - INFO - [MainThread] FirmwareUpdateChecker.FirmwareUpdateChecker.checkFirmwareVersion [74]: No machine with name Creality Ender-3 in list of firmware to check.
    2020-07-30 03:29:03,819 - DEBUG - [MainThread] cura.Machines.ContainerTree.__getitem__ [106]: Adding container tree for creality_ender3 took 0.47146105766296387 seconds.
    2020-07-30 03:29:03,823 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: BQ_PauseAtHeight
    2020-07-30 03:29:03,826 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ChangeAtZ
    2020-07-30 03:29:03,828 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: ColorMix
    2020-07-30 03:29:03,829 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayFilenameAndLayerOnLCD
    2020-07-30 03:29:03,830 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: DisplayRemainingTimeOnLCD
    2020-07-30 03:29:03,831 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: FilamentChange
    2020-07-30 03:29:03,833 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: InsertAtLayerChange
    2020-07-30 03:29:03,835 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeight
    2020-07-30 03:29:03,836 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightRepRapFirmwareDuet
    2020-07-30 03:29:03,838 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: PauseAtHeightforRepetier
    2020-07-30 03:29:03,839 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: RetractContinue
    2020-07-30 03:29:03,841 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: SearchAndReplace
    2020-07-30 03:29:03,844 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: Stretch
    2020-07-30 03:29:03,845 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: TimeLapse
    2020-07-30 03:29:03,846 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin.loadScripts [180]: Begin loading of script: UsePreviousProbeMeasurements
    2020-07-30 03:29:03,916 - INFO - [MainThread] cura.CuraApplication.run [756]: Initializing machine manager
    2020-07-30 03:29:03,919 - INFO - [MainThread] cura.CuraApplication.run [761]: Initializing container manager
    2020-07-30 03:29:03,923 - INFO - [Thread-2] STLReader.STLReader.load_file [52]: Using NumPy-STL to load STL data.
    2020-07-30 03:29:03,929 - DEBUG - [Thread-2] UM.Mesh.MeshData.calculateNormalsFromVertices [548]: Calculating normals took 0.0 seconds
    2020-07-30 03:29:03,931 - DEBUG - [Thread-2] STLReader.STLReader._read [104]: Loaded a mesh with 8520 vertices
    2020-07-30 03:29:04,002 - DEBUG - [MainThread] UM.Scene.Camera._preferencesChanged [255]: Changing perspective mode to perspective.
    2020-07-30 03:29:04,025 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-dark\theme.json
    2020-07-30 03:29:04,028 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [158]: Loading theme file: C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light\theme.json
    2020-07-30 03:29:04,255 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [231]: Loaded theme C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-light
    2020-07-30 03:29:04,255 - DEBUG - [MainThread] UM.Qt.Bindings.Theme.load [231]: Loaded theme C:\Program Files\Ultimaker Cura 4.6\resources\themes\cura-dark
    2020-07-30 03:29:04,630 - DEBUG - [MainThread] cura.Machines.MachineErrorChecker._rescheduleCheck [135]: New error check scheduled.
    2020-07-30 03:29:05,185 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [311]: Creating post processing plugin view.
    2020-07-30 03:29:05,327 - DEBUG - [MainThread] PostProcessingPlugin.PostProcessingPlugin._createView [321]: Post processing view created.
    2020-07-30 03:29:05,425 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:29:05,435 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService._parseJWT [89]: There was no auth data or access token
    2020-07-30 03:29:06,525 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:29:06,525 - WARNING - [MainThread] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x00000211BBA9E510> is deprecated (since 4.4): Please use extruderList instead.
    2020-07-30 03:29:06,635 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/PrintSetupSelector/Custom/CustomPrintSetup.qml:76:29: Unable to assign null to double
    2020-07-30 03:29:06,645 - DEBUG - [MainThread] UM.Controller.setActiveStage [180]: Setting active stage to PrepareStage
    2020-07-30 03:29:06,725 - DEBUG - [MainThread] cura.Machines.Models.NozzleModel._update [28]: Updating NozzleModel.
    2020-07-30 03:29:06,755 - WARNING - [MainThread] UM.Qt.QtApplication.__onQmlWarning [406]: file:///C:/Program Files/Ultimaker Cura 4.6/resources/qml/ActionButton.qml:101: ReferenceError: contentWidth is not defined
    2020-07-30 03:29:06,785 - DEBUG - [MainThread] UM.Controller.setActiveView [108]: Setting active view to SolidView
    2020-07-30 03:29:06,795 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [111]: Creating model checker view.
    2020-07-30 03:29:06,795 - DEBUG - [MainThread] ModelChecker.ModelChecker._createView [120]: Model checker view created.
    2020-07-30 03:29:06,795 - DEBUG - [MainThread] SliceInfoPlugin.SliceInfo._createDialog [71]: Creating dialog [MoreInfoWindow.qml]
    2020-07-30 03:29:06,825 - DEBUG - [MainThread] Toolbox.src.Toolbox._makeRequestByType [542]: Requesting [updates] metadata from server.
    2020-07-30 03:29:06,825 - DEBUG - [MainThread] cura.OAuth2.AuthorizationService.getAccessToken [112]: No auth data to retrieve the access_token from
    2020-07-30 03:29:06,825 - WARNING - [MainThread] UM.Logger.warning [128]: Cannot add authorization to Cloud Api request
    2020-07-30 03:29:06,835 - DEBUG - [MainThread] cura.CuraApplication.run [799]: Booting Cura took 9.39784550666809 seconds
    2020-07-30 03:29:06,845 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._processRequest [346]: Request [49da1f969ba84816bb7dba79b269535b] started
    2020-07-30 03:29:06,845 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:29:06,855 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:29:06,875 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:29:07,362 - DEBUG - [MainThread] cura.Machines.Models.QualityProfilesDropDownMenuModel._update [63]: Updating QualityProfilesDropDownMenuModel.
    2020-07-30 03:29:07,366 - DEBUG - [MainThread] cura.Machines.Models.CustomQualityProfilesDropDownMenuModel._update [34]: Updating CustomQualityProfilesDropDownMenuModel.
    2020-07-30 03:29:07,592 - DEBUG - [MainThread] UM.Qt.QtRenderer._initialize [207]: Support for Vertex Array Objects: True
    2020-07-30 03:29:07,601 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [112]: Initialized OpenGL subsystems.
    2020-07-30 03:29:07,604 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [113]: OpenGL Version:  4.1.0 - Build 26.20.100.7324
    2020-07-30 03:29:07,606 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [114]: OpenGL Vendor:   Intel
    2020-07-30 03:29:07,609 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [115]: OpenGL Renderer: Intel(R) UHD Graphics 630
    2020-07-30 03:29:07,611 - DEBUG - [MainThread] UM.View.GL.OpenGL.__init__ [116]: GLSL Version:    4.10.0
    2020-07-30 03:29:07,613 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:29:07,628 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\selection.shader]...
    2020-07-30 03:29:07,642 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\select_face.shader]...
    2020-07-30 03:29:07,655 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:29:07,670 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\composite.shader]...
    2020-07-30 03:29:07,692 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\overhang.shader]...
    2020-07-30 03:29:07,715 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\striped.shader]...
    2020-07-30 03:29:07,736 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\transparent_object.shader]...
    2020-07-30 03:29:07,750 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\striped.shader]...
    2020-07-30 03:29:07,770 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray.shader]...
    2020-07-30 03:29:07,783 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray_composite.shader]...
    2020-07-30 03:29:07,804 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\default.shader]...
    2020-07-30 03:29:07,819 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\grid.shader]...
    2020-07-30 03:29:07,833 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\platform.shader]...
    2020-07-30 03:29:07,869 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\xray.shader]...
    2020-07-30 03:29:08,489 - INFO - [MainThread] cura.Machines.MachineErrorChecker._setResult [187]: Error check finished, result = False, time = 3.9s
    2020-07-30 03:29:10,125 - INFO - [MainThread] UM.TaskManagement.HttpRequestManager._onRequestFinished [408]: Request [49da1f969ba84816bb7dba79b269535b] finished.
    2020-07-30 03:29:10,125 - DEBUG - [MainThread] UM.TaskManagement.HttpRequestManager._processNextRequestsInQueue [317]: No more requests to process, stop
    2020-07-30 03:29:16,841 - DEBUG - [MainThread] cura.AutoSave._onTimeout [60]: Autosaving preferences, instances and profiles
    2020-07-30 03:29:28,506 - INFO - [Thread-4] STLReader.STLReader.load_file [52]: Using NumPy-STL to load STL data.
    2020-07-30 03:29:28,838 - DEBUG - [Thread-4] UM.Mesh.MeshData.calculateNormalsFromVertices [548]: Calculating normals took 0.1376330852508545 seconds
    2020-07-30 03:29:28,889 - DEBUG - [Thread-4] STLReader.STLReader._read [104]: Loaded a mesh with 4670010 vertices
    2020-07-30 03:29:29,935 - DEBUG - [Thread-4] UM.Mesh.MeshData.approximateConvexHull [503]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 1.0363752841949463 seconds. 6444 input vertices. 6444 output vertices.
    2020-07-30 03:29:30,575 - DEBUG - [Thread-4] UM.FileHandler.ReadFileJob.run [71]: Loading file took 2.1 seconds
    2020-07-30 03:29:31,565 - DEBUG - [Thread-4] UM.Mesh.MeshData.approximateConvexHull [503]: approximateConvexHull(target_count=1024) Calculating 3D convex hull took 0.9870142936706543 seconds. 6443 input vertices. 6443 output vertices.
    2020-07-30 03:29:31,588 - DEBUG - [MainThread] UM.Operations.OperationStack.push [72]: <UM.Operations.AddSceneNodeOperation.AddSceneNodeOperation object at 0x00000211CA8CD4E0>, took 0ms
    2020-07-30 03:29:32,184 - INFO - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [237]: Starting to slice...
    2020-07-30 03:29:32,184 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend.slice [255]: Going to slice build plate [0]!
    2020-07-30 03:29:32,189 - WARNING - [Thread-5] UM.Decorators.deprecated_function [23]: <function GlobalStack.extruders at 0x00000211BBA9E510> is deprecated (since 4.4): Please use extruderList instead.
    2020-07-30 03:29:32,191 - DEBUG - [MainThread] UM.View.GL.ShaderProgram.load [58]: Loading shader file [C:\Program Files\Ultimaker Cura 4.6\resources\shaders\transparent_object.shader]...
    2020-07-30 03:29:32,630 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onStartSliceCompleted [444]: Sending slice message took 0.4448084831237793 seconds
    2020-07-30 03:29:34,457 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] [WARNING] Mesh has disconnected faces!
    2020-07-30 03:29:34,460 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] [WARNING] Mesh has overlapping faces!
    2020-07-30 03:29:35,403 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] [WARNING]  -s acceleration_support_infill="500" -s machine_settings="0" -s material_flow_dependent_temperature="False" -s retraction_retract_speed="25" -s wireframe_up_half_speed="0.3" -s support_type="everywhere" -s hole_xy_offset="0" -s z_seam_x="117.5" -s skirt_brim_speed="20.0" -s prime_tower_enable="False" -s infill_overlap_mm="0.12" -s infill_support_enabled="False" -s support_xy_distance="0.8" -s cool_fan_enabled="True" -s ironing_pattern="zigzag" -s machine_max_acceleration_y="500" -s jerk_topbottom="8" -s jerk_wall_0="8" -s ironing_line_spacing="0.1" -s speed_ironing="16.666666666666668" -s raft_base_line_width="0.8" -s wireframe_top_jump="0.6" -s machine_steps_per_mm_z="50" -s gradual_support_infill_step_height="1" -s wireframe_top_delay="0" -s support_skip_zag_per_mm="20" -s fill_outline_gaps="False" -s wireframe_drag_along="0.6" -s magic_fuzzy_skin_thickness="0.3" -s cool_min_layer_time_fan_speed_max="10" -s default_material_bed_temperature="50" -s acceleration_ironing="500" -s jerk_support_bottom="8" -s raft_interface_thickness="0.30000000000000004" -s infill_pattern="cubic" -s raft_surface_layers="2" -s travel="0" -s max_extrusion_before_wipe="10" -s wireframe_printspeed_bottom="5" -s mesh_position_y="0" -s small_feature_max_length="0.0" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s skirt_line_count="3" -s wipe_hop_speed="5" -s default_material_print_temperature="210" -s support_tower_maximum_supported_diameter="3.0" -s jerk_print_layer_0="8" -s jerk_enabled="False" -s flow_rate_max_extrusion_offset="0" -s machine_buildplate_type="glass" -s brim_gap="0" -s skin_no_small_gaps_heuristic="False" -s xy_offset="0" -s cool_fan_speed_0="0" -s acceleration_wall_0="500" -s machine_heated_build_volume="False" -s machine_name="Creality Ender-3" -s wireframe_roof_fall_down="2" -s machine_max_jerk_e="5" -s speed_support_infill="25.0" -s wall_line_width_x="0.4" -s bridge_skin_support_threshold="50" -s jerk_travel="8" -s material_anti_ooze_retraction_speed="5" -s infill_line_distance="6.0" -s switch_extruder_prime_speed="20" -s cool_lift_head="False" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s travel_compensate_overlapping_walls_enabled="True" -s small_hole_max_size="0" -s material_bed_temperature="50" -s support_line_width="0.4" -s wireframe_printspeed_up="5" -s support_interface_offset="0.0" -s minimum_roof_area="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s bridge_skin_speed_3="12.5" -s jerk_skirt_brim="8" -s support_brim_line_count="10" -s acceleration_support="500" -s travel_retract_before_outer_wall="True" -s wall_0_wipe_dist="0.0" -s wipe_hop_amount="0.2" -s top_layers="4" -s skirt_brim_line_width="0.4" -s support_infill_extruder_nr="0" -s speed_equalize_flow_max="150" -s wall_overhang_angle="90" -s speed_infill="50.0" -s draft_shield_enabled="False" -s prime_tower_line_width="0.4" -s retraction_combing_max_distance="30" -s material_adhesion_tendency="10" -s support_bottom_distance="0.2" -s acceleration_wall="500" -s machine_depth="235" -s raft_base_jerk="8" -s time="03:29:32" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s extruder_prime_pos_z="0" -s machine_nozzle_expansion_angle="45" -s clean_between_layers="False" -s support_roof_extruder_nr="0" -s material_print_temperature_layer_0="210" -s travel_avoid_distance="0.625" -s line_width="0.4" -s roofing_material_flow="100" -s wipe_retraction_retract_speed="25" -s travel_avoid_other_parts="True" -s z_seam_y="235" -s wireframe_printspeed_down="5" -s support_top_distance="0.2" -s machine_endstop_positive_direction_z="True" -s prime_tower_min_volume="6" -s wireframe_roof_inset="3" -s skin_material_flow="100" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s resolution="0" -s prime_tower_position_y="203.6" -s machine_max_feedrate_z="10" -s minimum_polygon_circumference="1.0" -s jerk_ironing="8" -s ooze_shield_dist="2" -s wireframe_height="3" -s layer_height="0.2" -s machine_show_variants="False" -s wall_thickness="0.8" -s spaghetti_inset="0.2" -s material_initial_print_temperature="210" -s filter_out_tiny_gaps="False" -s wireframe_nozzle_clearance="1" -s material_no_load_move_factor="0.940860215" -s speed_travel="150.0" -s mold_roof_height="0.5" -s top_skin_preshrink="0.8" -s draft_shield_dist="10" -s wireframe_fall_down="0.5" -s machine_height="250" -s support_tree_angle="40" -s initial_extruder_nr="0" -s nozzle_disallowed_areas="[]" -s meshfix_maximum_resolution="0.05" -s retraction_prime_speed="25" -s z_seam_type="back" -s acceleration_enabled="False" -s material_surface_energy="100" -s support_extruder_nr_layer_0="0" -s support_supported_skin_fan_speed="100" -s minimum_support_area="2" -s bottom_thickness="0.8" -s wireframe_bottom_delay="0" -s initial_layer_line_width_factor="100.0" -s wall_line_count="2" -s mold_angle="40" -s machine_max_acceleration_z="100" -s acceleration_print="500" -s material_standby_temperature="150" -s support_roof_density="33.333" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s mold_enabled="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s infill_overlap="30.0" -s wireframe_straight_before_down="20" -s bridge_skin_density_2="75" -s support_bottom_line_width="0.4" -s acceleration_support_roof="500" -s bridge_skin_speed_2="12.5" -s retraction_hop_after_extruder_switch="True" -s jerk_support_interface="8" -s jerk_layer_0="8" -s switch_extruder_retraction_speeds="20" -s machine_disallowed_areas="[[[-117.5, 117.5], [-117.5, 108], [117.5, 108], [117.5, 117.5]], [[-117.5, -108], [-117.5, -117.5], [117.5, -117.5], [117.5, -108]]]" -s raft_base_fan_speed="0" -s speed_print_layer_0="20.0" -s support_line_distance="2.0" -s machine_shape="rectangular" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_roof_enable="True" -s raft_surface_jerk="8" -s speed_z_hop="5" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s machine_max_feedrate_y="500" -s support_mesh_drop_down="True" -s raft_interface_fan_speed="0" -s top_bottom_thickness="0.8" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s carve_multiple_volumes="False" -s retraction_amount="6.5" -s fill_perimeter_gaps="everywhere" -s infill_material_flow="100" -s bridge_skin_density="100" -s material_print_temp_wait="True" -s support_bottom_height="0.8" -s gantry_height="25" -s support_interface_skip_height="0.2" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s prime_tower_position_x="223.6" -s raft_surface_thickness="0.2" -s small_feature_speed_factor_0="50" -s wipe_retraction_amount="6.5" -s machine_minimum_feedrate="0.0" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100.0" -s infill_multiplier="1" -s support_tree_branch_diameter_angle="5" -s wireframe_flow_connection="100" -s material_flush_purge_length="60" -s adaptive_layer_height_variation="0.04" -s flow_rate_extrusion_offset_factor="100" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s retraction_min_travel="1.5" -s magic_fuzzy_skin_outside_only="False" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_bottom_material_flow="100" -s infill_extruder_nr="-1" -s wireframe_enabled="False" -s material_diameter="1.75" -s outer_inset_first="False" -s center_object="False" -s raft_smoothing="5" -s jerk_support="8" -s adhesion_extruder_nr="0" -s relative_extrusion="False" -s material_bed_temp_prepend="True" -s raft_interface_speed="18.75" -s wall_line_width_0="0.4" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s wipe_pause="0" -s retraction_count_max="100" -s extruder_prime_pos_abs="False" -s ooze_shield_angle="60" -s adaptive_layer_height_variation_step="0.04" -s machine_end_gcode="G91 ;Relative positioning
    2020-07-30 03:29:35,405 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 E-2 F2700 ;Retract a bit
    2020-07-30 03:29:35,407 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 E-2 Z0.2 F2400 ;Retract and raise Z
    2020-07-30 03:29:35,410 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X5 Y5 F3000 ;Wipe out
    2020-07-30 03:29:35,413 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 Z10 ;Raise Z more
    2020-07-30 03:29:35,415 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G90 ;Absolute positionning
    2020-07-30 03:29:35,418 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:35,420 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0 Y235 ;Present print
    2020-07-30 03:29:35,422 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M106 S0 ;Turn-off fan
    2020-07-30 03:29:35,425 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M104 S0 ;Turn-off hotend
    2020-07-30 03:29:35,427 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M140 S0 ;Turn-off bed
    2020-07-30 03:29:35,430 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:35,432 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] M84 X Y E ;Disable all steppers but Z
    2020-07-30 03:29:35,434 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] " -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s raft_airgap="0.3" -s bridge_skin_material_flow="60" -s wireframe_printspeed="5" -s cutting_mesh="False" -s material_extrusion_cool_down_speed="0.7" -s machine_gcode_flavor="RepRap (Marlin/Sprinter)" -s material_guid="" -s connect_infill_polygons="False" -s support_xy_overrides_z="xy_overrides_z" -s skirt_brim_minimal_length="250" -s spaghetti_infill_extra_volume="0" -s spaghetti_max_infill_angle="10" -s support_interface_extruder_nr="0" -s infill_line_width="0.4" -s prime_tower_brim_enable="False" -s bottom_layers="4" -s meshfix="0" -s speed_wall_0="25.0" -s wall_x_extruder_nr="-1" -s coasting_volume="0.064" -s shell="0" -s travel_avoid_supports="True" -s material_end_of_filament_purge_length="20" -s support_connect_zigzags="True" -s support_bottom_offset="0.0" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s prime_tower_size="20" -s remove_empty_first_layers="True" -s support_roof_line_width="0.4" -s optimize_wall_printing_order="True" -s raft_base_speed="18.75" -s machine_heat_zone_length="16" -s date="30-07-2020" -s machine_start_gcode="; Ender 3 Custom Start G-code
    2020-07-30 03:29:35,436 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G92 E0 ; Reset Extruder
    2020-07-30 03:29:35,437 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G28 ; Home all axes
    2020-07-30 03:29:35,440 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2020-07-30 03:29:35,442 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.1 Y20 Z0.3 F5000.0 ; Move to start position
    2020-07-30 03:29:35,445 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.1 Y200.0 Z0.3 F1500.0 E15 ; Draw the first line
    2020-07-30 03:29:35,447 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.4 Y200.0 Z0.3 F5000.0 ; Move to side a little
    2020-07-30 03:29:35,449 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X0.4 Y20 Z0.3 F1500.0 E30 ; Draw the second line
    2020-07-30 03:29:35,452 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G92 E0 ; Reset Extruder
    2020-07-30 03:29:35,454 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
    2020-07-30 03:29:35,457 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] G1 X5 Y20 Z0.3 F5000.0 ; Move over to prevent blob squish" -s machine_max_acceleration_e="5000" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s spaghetti_infill_stepped="True" -s support_roof_material_flow="100" -s machine_steps_per_mm_e="1600" -s wall_0_extruder_nr="-1" -s machine_firmware_retract="False" -s infill_support_angle="40" -s material_bed_temperature_layer_0="50" -s roofing_layer_count="0" -s speed_slowdown_layers="2" -s speed_topbottom="25.0" -s wireframe_strategy="compensate" -s jerk_support_roof="8" -s wireframe_roof_drag_along="0.8" -s multiple_mesh_overlap="0.15" -s machine_max_jerk_z="0.4" -s acceleration_prime_tower="500" -s support_pattern="zigzag" -s support_initial_layer_line_distance="2.0" -s ironing_flow="10.0" -s support_enable="False" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s support_infill_rate="20" -s speed_equalize_flow_enabled="False" -s draft_shield_height="10" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s limit_support_retractions="True" -s acceleration_print_layer_0="500" -s bridge_enable_more_layers="True" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s machine_nozzle_size="0.4" -s skin_angles="[ ]" -s speed_support_bottom="25.0" -s wireframe_roof_outer_delay="0.2" -s machine_nozzle_head_distance="3" -s infill_mesh_order="0" -s cool_min_speed="10" -s machine_min_cool_heat_time_window="50.0" -s ironing_enabled="False" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100.0" -s switch_extruder_extra_prime_amount="0" -s support_conical_enabled="False" -s spaghetti_max_height="2.0" -s support_offset="0" -s bridge_fan_speed_2="0" -s support_bottom_enable="True" -s retraction_enable="True" -s infill_sparse_density="20" -s material_final_print_temperature="210" -s raft_jerk="8" -s wipe_hop_enable="False" -s machine_nozzle_heat_up_speed="2.0" -s speed_roofing="25.0" -s jerk_travel_layer_0="8" -s blackmagic="0" -s bridge_wall_material_flow="50" -s support_tree_enable="False" -s skin_overlap_mm="0.04" -s raft_margin="15" -s infill_mesh="False" -s wipe_move_distance="20" -s material_shrinkage_percentage="0" -s skin_line_width="0.4" -s coasting_enable="False" -s support_infill_sparse_thickness="0.2" -s support_conical_angle="30" -s bridge_wall_coast="100" -s wall_0_material_flow="100" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s sub_div_rad_add="0.4" -s mold_width="5" -s z_seam_position="back" -s speed="0" -s speed_print="50.0" -s brim_replaces_support="False" -s day="Thu" -s spaghetti_infill_enabled="False" -s acceleration_support_interface="500" -s wall_line_width="0.4" -s acceleration_travel="500" -s skirt_brim_material_flow="100" -s retraction_combing="noskin" -s wireframe_printspeed_flat="5" -s support_extruder_nr="0" -s layer_start_y="0.0" -s spaghetti_flow="20" -s prime_tower_wipe_enabled="True" -s bridge_skin_material_flow_3="110" -s prime_blob_enable="False" -s alternate_carve_order="True" -s material_break_preparation_retracted_position="-16" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s raft_acceleration="500" -s acceleration_wall_x="500" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s infill_offset_y="0" -s prime_tower_flow="100" -s raft_interface_acceleration="500" -s experimental="0" -s ironing_only_highest_layer="False" -s bridge_settings_enabled="False" -s mesh_position_x="0" -s extruder_prime_pos_x="0" -s wipe_retraction_speed="25" -s meshfix_union_all="True" -s machine_extruder_count="1" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s wall_0_inset="0" -s speed_support_interface="25.0" -s ironing_inset="0.2" -s skin_preshrink="0.8" -s minimum_interface_area="10" -s infill_before_walls="False" -s material="0" -s expand_skins_expand_distance="0.8" -s coasting_speed="90" -s speed_wall="25.0" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s zig_zaggify_infill="False" -s material_flow_layer_0="100" -s material_anti_ooze_retracted_position="-4" -s layer_height_0="0.2" -s support_roof_angles="[ ]" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.05" -s machine_max_acceleration_x="500" -s jerk_wall="8" -s infill_offset_x="0" -s machine_steps_per_mm_x="50" -s raft_interface_jerk="8" -s machine_nozzle_temp_enabled="True" -s raft_surface_speed="25.0" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s support_interface_material_flow="100" -s speed_wall_x="25.0" -s material_print_temp_prepend="True" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s machine_acceleration="500" -s min_skin_width_for_expansion="4.898587196589413e-17" -s jerk_wall_x="8" -s machine_center_is_zero="False" -s ooze_shield_enabled="False" -s bridge_fan_speed="100" -s support_wall_count="1" -s meshfix_maximum_travel_resolution="0.05" -s retraction_speed="25" -s wipe_retraction_prime_speed="25" -s support_material_flow="100" -s travel_compensate_overlapping_walls_0_enabled="False" -s support_mesh="False" -s slicing_tolerance="middle" -s roofing_pattern="lines" -s support_interface_pattern="grid" -s wall_material_flow="100" -s raft_fan_speed="0" -s acceleration_infill="500" -s wireframe_flat_delay="0.1" -s magic_fuzzy_skin_enabled="False" -s draft_shield_height_limitation="full" -s bridge_wall_min_length="5" -s alternate_extra_perimeter="False" -s retraction_hop="0.2" -s dual="0" -s material_break_temperature="50" -s adaptive_layer_height_enabled="False" -s machine_use_extruder_offset_to_offset_coords="True" -s machine_endstop_positive_direction_x="False" -s machine_max_feedrate_x="500" -s infill_wall_line_count="0" -s conical_overhang_enabled="False" -s raft_speed="25.0" -s support_roof_pattern="grid" -s adaptive_layer_height_threshold="0.2" -s jerk_prime_tower="8" -s print_bed_temperature="50" -s machine_width="235" -s acceleration_travel_layer_0="500" -s support_bottom_stair_step_height="0.3" -s magic_spiralize="False" -s machine_extruders_share_heater="False" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="210" -s machine_head_with_fans_polygon="[[-26, 34], [-26, -32], [32, -32], [32, 34]]" -s wall_extruder_nr="-1" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s support_angle="45" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s material_bed_temp_wait="True" -s conical_overhang_angle="50" -s speed_support_roof="25.0" -s material_print_temperature="210" -s adhesion_type="skirt" -s roofing_line_width="0.4" -s wireframe_flow_flat="100" -s support_bottom_angles="[ ]" -s material_break_preparation_speed="2" -s wireframe_flow="100" -s speed_travel_layer_0="100.0" -s support_bottom_extruder_nr="0" -s infill="0" -s raft_interface_line_spacing="1.0" -s support_tree_collision_resolution="0.2" -s support_join_distance="2.0" -s machine_nozzle_cool_down_speed="2.0" -s wall_min_flow_retract="False" -s jerk_infill="8" -s bridge_wall_speed="12.5" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s magic_fuzzy_skin_point_density="1.25" -s machine_heated_bed="True" -s support_bottom_stair_step_width="5.0" -s build_volume_temperature="28" -s bottom_skin_expand_distance="0.8" -s switch_extruder_retraction_speed="20" -s anti_overhang_mesh="False" -s top_bottom_extruder_nr="-1" -s gradual_support_infill_steps="0" -s roofing_extruder_nr="-1" -s cool_fan_speed_max="100.0" -s support_interface_angles="[ ]" -s machine_feeder_wheel_diameter="10.0" -s support_bottom_density="33.333" -s support_xy_distance_overhang="0.4" -s print_sequence="all_at_once" -s infill_angles="[ ]" -s machine_max_feedrate_e="50" -s top_bottom_pattern_0="lines" -s raft_surface_line_width="0.4" -s retraction_hop_only_when_collides="False" -s cooling="0" -s retraction_extra_prime_amount="0" -s bridge_sparse_infill_max_density="0" -s print_temperature="210" -s acceleration_skirt_brim="500" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s gradual_infill_steps="0" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s material_flow="100" -s retraction_extrusion_window="10" -s retraction_hop_after_extruder_switch_height="0.2" -s z_seam_relative="False" -s small_feature_speed_factor="50" -s bottom_skin_preshrink="0.8" -s top_thickness="0.8" -s platform_adhesion="0" -s support_tower_roof_angle="65" -s command_line_settings="0" -s acceleration_support_bottom="500" -s jerk_print="8" -s extruder_prime_pos_y="0" -s extruders_enabled_count="1" -s brim_width="8.0" -s support_bottom_line_distance="2.4000240002400024" -s wall_min_flow="0" -s travel_speed="150.0" -s material_flush_purge_speed="0.5" -s bridge_fan_speed_3="0" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s raft_surface_fan_speed="0" -s connect_skin_polygons="False" -s support_z_distance="0.2" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s retract_at_layer_change="False" -s wipe_brush_pos_x="100" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s raft_surface_acceleration="500" -s support_interface_height="0.8" -s machine_max_jerk_xy="10" -s smooth_spiralized_contours="True" -e0 -s acceleration_support_infill="500" -s resolution="0" -s machine_settings="0" -s machine_extruder_end_pos_x="0" -s material_flow_dependent_temperature="False" -s retraction_retract_speed="45" -s bridge_sparse_infill_max_density="0" -s hole_xy_offset="0" -s z_seam_x="117.5" -s skirt_brim_speed="20.0" -s infill_overlap_mm="0.12" -s material_break_preparation_speed="2" -s infill_support_enabled="False" -s support_xy_distance="0.8" -s cool_fan_enabled="True" -s ironing_pattern="zigzag" -s jerk_topbottom="8" -s jerk_wall_0="8" -s ironing_line_spacing="0.1" -s speed_ironing="16.666666666666668" -s raft_base_line_width="0.8" -s machine_steps_per_mm_z="50" -s gradual_support_infill_step_height="1" -s support_skip_zag_per_mm="20" -s fill_outline_gaps="False" -s magic_fuzzy_skin_thickness="0.3" -s cool_min_layer_time_fan_speed_max="10" -s acceleration_ironing="500" -s jerk_support_bottom="8" -s raft_interface_thickness="0.30000000000000004" -s infill_pattern="cubic" -s raft_surface_layers="2" -s travel="0" -s max_extrusion_before_wipe="10" -s retraction_prime_speed="45" -s z_seam_type="back" -s travel_compensate_overlapping_walls_0_enabled="False" -s mesh_position_y="0" -s small_feature_max_length="0.0" -s acceleration_layer_0="500" -s skin_overlap="10.0" -s skirt_line_count="3" -s wipe_hop_speed="5" -s default_material_print_temperature="200" -s support_tower_maximum_supported_diameter="3.0" -s jerk_print_layer_0="8" -s brim_gap="0" -s skin_no_small_gaps_heuristic="False" -s xy_offset="0" -s cool_fan_speed_0="0" -s acceleration_wall_0="500" -s machine_extruder_end_pos_abs="False" -s speed_support_infill="25.0" -s wall_line_width_x="0.4" -s bridge_skin_support_threshold="50" -s material_anti_ooze_retraction_speed="5" -s infill_line_distance="6.0" -s roofing_line_width="0.4" -s speed_travel_layer_0="100.0" -s switch_extruder_prime_speed="20" -s cool_lift_head="False" -s support_interface_line_width="0.4" -s wall_x_material_flow="100" -s material_extrusion_cool_down_speed="0.7" -s travel_compensate_overlapping_walls_enabled="True" -s small_hole_max_size="0" -s support_line_width="0.4" -s machine_extruder_start_pos_x="0" -s extruder_prime_pos_z="0" -s support_interface_offset="0.0" -s minimum_roof_area="10" -s cool_fan_full_layer="4" -s infill_enable_travel_optimization="False" -s bridge_skin_speed_3="12.5" -s jerk_skirt_brim="8" -s support_brim_line_count="10" -s acceleration_support="500" -s wall_0_wipe_dist="0.0" -s wipe_hop_amount="0.2" -s top_layers="4" -s skirt_brim_line_width="0.4" -s speed_equalize_flow_max="150" -s wall_overhang_angle="90" -s speed_infill="50.0" -s prime_tower_line_width="0.4" -s machine_extruder_start_pos_y="0" -s support_wall_count="1" -s bridge_fan_speed="100" -s material_anti_ooze_retracted_position="-4" -s support_roof_angles="[ ]" -s material_flow_layer_0="100" -s infill_wipe_dist="0.0" -s meshfix_maximum_deviation="0.05" -s material_break_speed="25" -s skin_edge_support_layers="0" -s support="0" -s bridge_fan_speed_2="0" -s support_offset="0" -s raft_interface_jerk="8" -s material_flow_temp_graph="[[3.5,200],[7.0,240]]" -s min_skin_width_for_expansion="4.898587196589413e-17" -s roofing_material_flow="100" -s zig_zaggify_infill="False" -s machine_nozzle_heat_up_speed="2.0" -s wipe_hop_enable="False" -s minimum_interface_area="10" -s infill_before_walls="False" -s acceleration_print="500" -s material_standby_temperature="180" -s support_roof_density="33.333" -s infill_sparse_thickness="0.2" -s support_fan_enable="False" -s jerk_travel="8" -s machine_extruder_cooling_fan_number="0" -s support_bottom_offset="0.0" -s magic_mesh_surface_mode="normal" -s coasting_min_volume="0.8" -s mold_enabled="False" -s skin_outline_count="1" -s acceleration_topbottom="500" -s layer_start_x="0.0" -s min_infill_area="0" -s support_brim_enable="True" -s infill_overlap="30.0" -s bridge_skin_density_2="75" -s gradual_infill_step_height="1.5" -s support_conical_min_width="5.0" -s support_bottom_line_width="0.4" -s spaghetti_inset="0.2" -s acceleration_support_roof="500" -s speed_print_layer_0="20.0" -s support_line_distance="2.0" -s bridge_skin_speed_2="12.5" -s jerk_layer_0="8" -s raft_jerk="8" -s material_final_print_temperature="200" -s support_tree_angle="40" -s switch_extruder_retraction_speeds="20" -s raft_base_fan_speed="0" -s machine_extruder_end_code="" -s skin_angles="[ ]" -s support_roof_offset="0.0" -s cross_infill_density_image="" -s brim_outside_only="True" -s support_roof_line_distance="2.4000240002400024" -s support_roof_enable="True" -s material_no_load_move_factor="0.940860215" -s raft_smoothing="5" -s jerk_support="8" -s small_feature_speed_factor_0="50" -s wipe_retraction_amount="5" -s machine_steps_per_mm_y="50" -s cool_fan_speed="100" -s blackmagic="0" -s material_maximum_park_duration="300" -s top_bottom_pattern="lines" -s infill_line_width="0.4" -s spaghetti_infill_extra_volume="0" -s spaghetti_max_infill_angle="10" -s top_bottom_thickness="0.8" -s support_tree_branch_diameter="2" -s roofing_angles="[ ]" -s z_seam_corner="z_seam_corner_weighted" -s retraction_amount="5" -s fill_perimeter_gaps="everywhere" -s infill_material_flow="100" -s bridge_skin_density="100" -s bridge_skin_material_flow="60" -s raft_airgap="0.3" -s support_bottom_height="0.8" -s support_interface_skip_height="0.2" -s bridge_enable_more_layers="True" -s raft_base_acceleration="500" -s wall_overhang_speed_factor="100" -s speed_support_bottom="25.0" -s machine_nozzle_head_distance="3" -s skirt_brim_material_flow="100" -s raft_surface_speed="25.0" -s center_object="False" -s support_roof_line_width="0.4" -s optimize_wall_printing_order="True" -s raft_base_speed="18.75" -s material_surface_energy="100" -s machine_steps_per_mm_e="1600" -s support_infill_rate="20" -s speed_equalize_flow_enabled="False" -s speed_z_hop="5" -s raft_surface_jerk="8" -s wipe_retraction_enable="True" -s magic_fuzzy_skin_point_dist="0.8" -s support_use_towers="False" -s jerk_support_infill="8" -s jerk_wall_x="8" -s retraction_count_max="100" -s skin_material_flow="100" -s extruder_prime_pos_abs="False" -s raft_base_thickness="0.24" -s zig_zaggify_support="False" -s material_adhesion_tendency="0" -s material_crystallinity="False" -s raft_base_line_spacing="1.6" -s speed_roofing="25.0" -s jerk_travel_layer_0="8" -s skin_edge_support_thickness="0" -s brim_line_count="20" -s machine_nozzle_size="0.4" -s bottom_layers="4" -s coasting_volume="0.064" -s shell="0" -s travel_avoid_supports="True" -s skirt_brim_minimal_length="250" -s support_xy_overrides_z="xy_overrides_z" -s speed_wall_0="25.0" -s meshfix="0" -s bridge_skin_material_flow_3="110" -s material_guid="0ff92885-617b-4144-a03c-9989872454bc" -s connect_infill_polygons="False" -s support_roof_material_flow="100" -s spaghetti_infill_stepped="True" -s retraction_speed="45" -s meshfix_maximum_travel_resolution="0.05" -s skin_overlap_mm="0.04" -s machine_heat_zone_length="16" -s support_interface_material_flow="100" -s speed_wall_x="25.0" -s support_initial_layer_line_distance="2.0" -s ironing_flow="10.0" -s support_tree_branch_diameter_angle="5" -s raft_base_jerk="8" -s support_bottom_enable="True" -s retraction_enable="True" -s infill_sparse_density="20" -s jerk_support_roof="8" -s extruder_prime_pos_y="0" -s ironing_enabled="False" -s support_tree_branch_distance="1" -s cool_fan_speed_min="100" -s switch_extruder_extra_prime_amount="0" -s support_conical_enabled="False" -s spaghetti_max_height="2.0" -s machine_extruder_start_pos_abs="False" -s infill_multiplier="1" -s raft_surface_thickness="0.2" -s machine_extruder_start_code="" -s z_seam_y="235" -s support_bottom_distance="0.2" -s acceleration_wall="500" -s layer_start_y="0.0" -s spaghetti_flow="20" -s prime_tower_wipe_enabled="True" -s support_bottom_material_flow="100" -s machine_min_cool_heat_time_window="50.0" -s cool_min_speed="10" -s travel_compensate_overlapping_walls_x_enabled="True" -s support_pattern="zigzag" -s infill_support_angle="40" -s support_xy_distance_overhang="0.4" -s speed_topbottom="25.0" -s prime_blob_enable="False" -s sub_div_rad_add="0.4" -s wipe_retraction_extra_prime_amount="0" -s bridge_skin_density_3="80" -s cool_min_layer_time="10" -s raft_surface_line_spacing="0.4" -s material_break_retracted_position="-50" -s bridge_wall_material_flow="50" -s meshfix_union_all="True" -s wipe_retraction_speed="45" -s extruder_prime_pos_x="0" -s acceleration_support_interface="500" -s wall_line_width="0.4" -s acceleration_travel="500" -s support_conical_angle="30" -s wall_line_count="2" -s outer_inset_first="False" -s wall_0_material_flow="100" -s bridge_wall_coast="100" -s support_tower_diameter="3.0" -s material_end_of_filament_purge_speed="0.5" -s material_break_preparation_retracted_position="-16" -s support_interface_density="33.333" -s mesh_rotation_matrix="[[1,0,0], [0,1,0], [0,0,1]]" -s machine_nozzle_offset_x="0" -s raft_acceleration="500" -s bridge_skin_material_flow_2="100" -s machine_endstop_positive_direction_y="False" -s acceleration_wall_x="500" -s support_connect_zigzags="True" -s material_end_of_filament_purge_length="20" -s mold_width="5" -s machine_endstop_positive_direction_z="True" -s switch_extruder_retraction_amount="16" -s cross_support_density_image="" -s meshfix_keep_open_polygons="False" -s minimum_bottom_area="10" -s infill_offset_y="0" -s support_interface_enable="True" -s support_brim_width="4" -s support_roof_height="0.8" -s coasting_speed="90" -s speed_wall="25.0" -s bottom_thickness="0.8" -s prime_tower_flow="100" -s material_diameter="1.75" -s raft_interface_acceleration="500" -s experimental="0" -s magic_fuzzy_skin_outside_only="False" -s retraction_min_travel="1.5" -s layer_0_z_overlap="0.15" -s speed_layer_0="20.0" -s infill_randomize_start_location="False" -s top_skin_expand_distance="0.8" -s roofing_layer_count="0" -s wall_0_inset="0" -s speed_support_interface="25.0" -s ironing_inset="0.2" -s skin_preshrink="0.8" -s machine_steps_per_mm_x="50" -s skirt_gap="10.0" -s support_zag_skip_count="10" -s wipe_pause="0" -s z_seam_position="back" -s speed="0" -s speed_print="50.0" -s brim_replaces_support="False" -s machine_nozzle_temp_enabled="True" -s material="0" -s expand_skins_expand_distance="0.8" -s support_supported_skin_fan_speed="100" -s infill_offset_x="0" -s jerk_wall="8" -s speed_travel="150.0" -s ironing_only_highest_layer="False" -s mesh_position_x="0" -s wipe_retraction_prime_speed="45" -s support_material_flow="100" -s slicing_tolerance="middle" -s roofing_pattern="lines" -s acceleration_infill="500" -s magic_fuzzy_skin_enabled="False" -s prime_tower_min_volume="6" -s acceleration_roofing="500" -s retraction_hop_enabled="False" -s alternate_extra_perimeter="False" -s material_break_temperature="50" -s machine_endstop_positive_direction_x="False" -s infill_wall_line_count="0" -s conical_overhang_enabled="False" -s support_roof_pattern="grid" -s raft_speed="25.0" -s machine_extruder_end_pos_y="0" -s jerk_prime_tower="8" -s acceleration_travel_layer_0="500" -s extruder_nr="0" -s support_infill_angles="[ ]" -s material_break_preparation_temperature="200" -s max_skin_angle_for_expansion="90" -s machine_nozzle_tip_outer_diameter="1" -s support_angle="45" -s conical_overhang_angle="50" -s speed_support_roof="25.0" -s material_print_temperature="200" -s speed_prime_tower="25.0" -s mesh_position_z="0" -s support_bottom_angles="[ ]" -s infill="0" -s raft_interface_line_spacing="1.0" -s support_tree_collision_resolution="0.2" -s wipe_retraction_retract_speed="45" -s support_join_distance="2.0" -s machine_nozzle_cool_down_speed="2.0" -s bridge_wall_speed="12.5" -s xy_offset_layer_0="0" -s meshfix_union_all_remove_holes="False" -s magic_fuzzy_skin_point_density="1.25" -s support_bottom_stair_step_width="5.0" -s gradual_support_infill_steps="0" -s cool_fan_speed_max="100" -s support_interface_angles="[ ]" -s infill_angles="[ ]" -s top_bottom_pattern_0="lines" -s raft_surface_line_width="0.4" -s mold_roof_height="0.5" -s retraction_hop_only_when_collides="False" -s cooling="0" -s retraction_extra_prime_amount="0" -s raft_interface_fan_speed="0" -s acceleration_skirt_brim="500" -s raft_interface_line_width="0.8" -s meshfix_extensive_stitching="False" -s clean_between_layers="False" -s gradual_infill_steps="0" -s material_print_temperature_layer_0="200" -s travel_avoid_distance="0.625" -s initial_bottom_layers="4" -s cool_fan_full_at_height="0.6000000000000001" -s support_bottom_density="33.333" -s machine_feeder_wheel_diameter="10.0" -s material_flow="100" -s retraction_extrusion_window="10" -s spaghetti_infill_enabled="False" -s initial_layer_line_width_factor="100.0" -s retraction_hop_after_extruder_switch_height="0.2" -s z_seam_relative="False" -s small_feature_speed_factor="50" -s bottom_skin_preshrink="0.8" -s raft_interface_speed="18.75" -s wall_line_width_0="0.4" -s retraction_combing_max_distance="30" -s top_thickness="0.8" -s platform_adhesion="0" -s support_tower_roof_angle="65" -s acceleration_support_bottom="500" -s command_line_settings="0" -s jerk_print="8" -s minimum_support_area="2" -s material_flush_purge_length="60" -s machine_nozzle_offset_y="0" -s line_width="0.4" -s brim_width="8.0" -s support_bottom_line_distance="2.4000240002400024" -s wall_min_flow="0" -s material_flush_purge_speed="0.5" -s jerk_support_interface="8" -s retraction_hop_after_extruder_switch="True" -s bridge_fan_speed_3="0" -s support_skip_some_zags="False" -s wipe_repeat_count="5" -s raft_surface_fan_speed="0" -s cross_infill_pocket_size="6.0" -s speed_support="25.0" -s retract_at_layer_change="False" -s wipe_brush_pos_x="100" -s bridge_skin_speed="12.5" -s jerk_roofing="8" -s raft_surface_acceleration="500" -s support_interface_height="0.8" -s mold_angle="40" -s jerk_infill="8" -s wall_min_flow_retract="False" -s support_bottom_stair_step_height="0.3" -s meshfix_maximum_resolution="0.05" -s dual="0" -s retraction_hop="0.2" -s top_skin_preshrink="0.8" -s filter_out_tiny_gaps="False" -s material_initial_print_temperature="200" -s wall_thickness="0.8" -s acceleration_prime_tower="500" -s multiple_mesh_overlap="0.15" -s jerk_ironing="8" -s raft_margin="15" -s support_bottom_pattern="grid" -s machine_nozzle_id="unknown" -s support_top_distance="0.2" -s travel_avoid_other_parts="True" -s support_z_distance="0.2" -s connect_skin_polygons="False" -s wall_material_flow="100" -s raft_fan_speed="0" -s support_interface_pattern="grid" -s switch_extruder_retraction_speed="20" -s bottom_skin_expand_distance="0.8" -s support_infill_sparse_thickness="0.2" -s coasting_enable="False" -s acceleration_print_layer_0="500" -s limit_support_retractions="True" -s material_shrinkage_percentage="0" -s skin_line_width="0.4" -s wipe_move_distance="20" -g -e0 -l "0" -s extruder_nr="0"
    2020-07-30 03:29:36,815 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._onBackendQuit [844]: Backend quit with return code 3221225477. Resetting process and socket.
    2020-07-30 03:29:37,059 - INFO - [MainThread] UM.Backend.Backend._onSocketError [214]: Backend crashed or closed.
    2020-07-30 03:29:37,061 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first.
    2020-07-30 03:29:37,063 - DEBUG - [MainThread] CuraEngineBackend.CuraEngineBackend._terminate [304]: Attempting to kill the engine process
    2020-07-30 03:29:37,066 - DEBUG - [MainThread] UM.Backend.Backend._createSocket [227]: Previous socket existed. Closing that first.
    2020-07-30 03:29:37,070 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [184]: Socket state changed to Listening
    2020-07-30 03:29:37,082 - INFO - [MainThread] UM.Backend.Backend.startEngine [86]: Started engine process: C:\Program Files\Ultimaker Cura 4.6\CuraEngine.exe
    2020-07-30 03:29:37,085 - DEBUG - [MainThread] UM.Backend.Backend._backendLog [106]: [Backend] Calling engine with: ['C:\\Program Files\\Ultimaker Cura 4.6\\CuraEngine.exe', 'connect', '127.0.0.1:49674', '']
    2020-07-30 03:29:37,119 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,121 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] Cura_SteamEngine version 4.6.2
    2020-07-30 03:29:37,123 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] Copyright (C) 2019 Ultimaker
    2020-07-30 03:29:37,125 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,128 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] This program is free software: you can redistribute it and/or modify
    2020-07-30 03:29:37,131 - DEBUG - [MainThread] UM.Backend.Backend._logSocketState [188]: Socket state changed to Connected
    2020-07-30 03:29:37,133 - DEBUG - [MainThread] UM.Backend.Backend._onSocketStateChanged [177]: Backend connected on port 49674
    2020-07-30 03:29:37,134 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] it under the terms of the GNU Affero General Public License as published by
    2020-07-30 03:29:37,137 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] the Free Software Foundation, either version 3 of the License, or
    2020-07-30 03:29:37,139 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] (at your option) any later version.
    2020-07-30 03:29:37,141 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,143 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] This program is distributed in the hope that it will be useful,
    2020-07-30 03:29:37,145 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] but WITHOUT ANY WARRANTY; without even the implied warranty of
    2020-07-30 03:29:37,147 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    2020-07-30 03:29:37,149 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] GNU Affero General Public License for more details.
    2020-07-30 03:29:37,151 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend]
    2020-07-30 03:29:37,153 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] You should have received a copy of the GNU Affero General Public License
    2020-07-30 03:29:37,155 - DEBUG - [EngineErrorThread] UM.Backend.Backend._backendLog [106]: [Backend] along with this program.  If not, see <http://www.gnu.org/licenses/>.
    Posted (edited) · Can't slice tolerance.stl file
    Don't read too much into the wording "EngineErrorThread". This is the interesting bit:
    Any time the CuraEngine process quits with an errorcode that does not equal 0, that means that the slicer has crashed. 3111225477 is C0000005 in hexadecimal. Update: C0000005 is normally an "ACCESS_VIOLATION", meaning CuraEngine is trying to read or write memory where it is not supposed to. So definitely a bug, related to either the model or the settings.
    It will be helpful to debug this if you save the model as a project via File -> Save... (NOT File -> Export). This will save the model and all your settings.
    Edited by ahoeben
    Posted · Can't slice tolerance.stl file
    I wasn't sure if you were wanting me to save the model as a project and send over the log file again, but here it is in case you need it.
    cura.log
    I've also used a different model from Thingiverse to see if the problem persisted, and it did.
    https://www.thingiverse.com/thing:4038181/files
    Also, here's a WeTransfer link of the Tolerance.STL file that's saved as a project.
    I've cycled through the default Cura profiles with no luck.
    https://we.tl/t-VrOe1gBhZX
    Edited by Digital101
    Did you find an answer ahoeben? I'm experiencing this too, still in 5.6.0. It crashes right after "Time spent with creating influence areas' subtasks:" specifically when using tree supports
          • Heart
        • 4 replies
