Cura 4.6.1 segfaulting with Artemis/Duet
brianmichalk
Posted · Cura 4.6.1 segfaulting with Artemis/Duet
I upgraded the Duet Wifi plugin, and now Cura segfaults quite often after sending the job to the printer.  Sometimes the printer gets everything and proceeds to print, sometimes not.  I can usually get one print job out without crashing, but the second job seems to reliably crash.  I'm pretty sure it's a problem with the plugin.
    I was confused that the 1.0.10 version had not changed even though there were commits.  Anyway, I am now using the latest Git plugin, and am experiencing the same thing.  I'll work with Thomas on this.
        • 27 replies
