Also, if you can post one of the test print gcode files that would be great because we can then compare it to what Cura is producing. Thanks.
😄 I see you’re thinking the same thing I did. I opened them side by side in notepad++ and compared. The sample was done in simplify3D. I’ll post them as soon as I get home
Ok, so either the manufacturer is a week behind, or they read this forum. I sent them an email about a week ago asking what could cause the issue and go no reply, I post the question here and while I was at work they sent me an email with a firmware update. I just got home and updated it, it’s all working now.
I'm just glad it wasn’t something I was doing wrong, I was beginning to wonder if I just got lucky with all my other equipment 😄
thank you for the reply, we can mark this one as “solved” it was a firmware issue.
OK, glad it's solved, happy printing!
- 1 month later...
I was just driving myself going through the exact same issue. I cannot find the firmware update for 5X. Do you happen to know where these are located I have reached out to ANet, but figured this may be a faster way to get up and running.
burtoogle 515
Could you please post a sample gcode file that exhibits this behaviour? At least we could then check it for obvious problems.
