4.7 Beta Print Settings Expansion
MattOH
Posted · 4.7 Beta Print Settings Expansion
Hi there! I just installed the 4.7 beta last night and I noticed that the expansion arrows for a few of the sections don't update when they are expanded or collapsed. Specifically, the Quality, Infill, Support, and Build Plate Adhesion sections. Seems like a small bug but I was wondering if anyone knew how to report it? Thanks!
    Hi @MattOH, if you click that little 'hamburger' next to the search bar you can select 'Manage Setting Visibility'. In that window that will open you can select which features you want to have visible in your view. There are also some presets available that range from 'basic' to 'all'.
    Thank you for the help finding that, I had never noticed that menu before. I have Custom selected, and as you can see in this screenshot, there are settings below the various sections but they're still not updating when you expand a section.Cura2.thumb.png.95b671ce4878d817188505c05197908a.png
        • 26 replies
