On 8/12/2020 at 5:43 AM, nallath said:What visibility preset do you have active?
I have no idea what that means.
Hi @MattOH, if you click that little 'hamburger' next to the search bar you can select 'Manage Setting Visibility'. In that window that will open you can select which features you want to have visible in your view. There are also some presets available that range from 'basic' to 'all'.
nallath 1,123
