DivingDuck 105
Hi Sander,
Thanks for your answer. Correct, nothing was responding anymore and I recognize this when hitting the submit button and nothing happen. I'm guess I hit the button central right in the middle and try to do it more than one time. I will look closer to this when it happen again. Today it didn't happen so fare.
I was a little bit busy the last days with other work including tests with the actual beta version 🙂
SandervG 1,521
Hi DD,
thank you for your message. Does nothing respond anymore, or are you trying to hit 'submit' and it doesn't respond? What I have noticed it that when the submit button is exactly next to the chatbot, there is a small area reserved by the chatbot that is non-clickable for when the chat opens. If this is the case, perhaps you can try to scroll up a little bit until it is above the 'How can we help' and it should work. Could this be it?
The Ultimaker forum is part of our ecosystem and since we introduced Ultimaker accounts they have been synced. Which means if you create an Ultimaker account in Cura you also gain access to the community with your account.
