Unable to change material settings for Ultimaker2Go
medicalmodeller
Posted · Unable to change material settings for Ultimaker2Go
I have an U3 and a U2+ and am used to creating and changing material profiles within Cura
I have now bought an Ultimaker2Go.   I have launched Cura and chosen U2Go as my printer.   When I try to change the material settings they are all grey out and cannot be changed.
Help!   Surely I do not have to accept the default settings?
Thanks
MM
    I am not sure that I understand.   FOr the UM2+ all I did was select UM2+ and Cura does the rest
    I think that the issue is that the U2Go is set to only use PLA so users are not expected to change to anything else.   I do not know how to change the GCode Flavor
    MM
