Thanks very much Greg, some of those I've done, but a couple I haven't so I appreciate the checklist.
The machine uses Marlin, I'll check Cura.
Question, when you write the gcode to the card from Cura, and use that, is it not giving the same instructions as over the USB? I experiment with the card though, and see if there's a difference.
Thanks,
Cliff
GregValiant 1,141
I don't know much about that printer. Looks like an open frame design likely running Marlin firmware. There are general things that can be checked though.
Check within Cura and find the filament diameter. Make sure it is set to 1.75mm.
Check that the "Firmware Flavor" matches your machine (Marlin?).
Check that the nozzle setting reflects what you actually have installed.
If the printer came with an SD card are there sample Gcode files on it? I would start by printing one of the samples to make sure everything is working as it should.
It looks like the machine has an adjuster for filament tension on the extruder. Make sure there is no slippage there when extruding.
Have you calibrated the steps/mm of all 4 axis? If the printer is told to push 100mm and it only pushes 90mm then there will be under-extrusion.
When you change the Flow in Cura, all the other flows should update to match it. Double check "Initial Layer Flow". Make sure that one matches the rest of them.
There are downsides to printing over the USB. I much prefer using the SD card.
